Oil leak, ideas?
Old Jan 23, 2009 | 10:15 AM
JROW's Avatar
JROW
Default Oil leak, ideas?
My 99 coupe has recently developed an oil leak. I've noticed spots on the driveway coming from the very front of the car. Hopefully get it on a lift today. Any ideas or common oil leak issues I should look out for?
Just glad it's not the differential, at least I think!
Old Jan 23, 2009 | 10:35 AM
sikpuppy's Avatar
sikpuppy
St. Jude Donor '08
Best bet would be the front main seal. Won't cost much if you do it your self but for a shop, depending on labor rates, but somewhere around $250.00 - $350.00. Good luck!
Old Jan 23, 2009 | 10:49 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Are you sure that it's oil? Coolant will also leave oily spots on a driveway.
Put some plastic sheeting under the car where you park, to help determine what the fluid is.
Old Jan 23, 2009 | 12:58 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
It could be from anywhere. My '99 developed a leak which turned out to the pan gasket. Replaced it with no more and no more leak.
Old Jan 24, 2009 | 03:42 PM
FL_Dave's Avatar
FL_Dave
Default Ac
It could also be oil from the air conditioning. I had that problem on an '00 and thought it was engine oil at first. If so, the likely location is where the "line set" plugs into the back of the AC compressor. This can be inexpensive to repair. You can search my name for a post on how to DIY the fix.
Old Jan 24, 2009 | 04:42 PM
lp2k's Avatar
lp2k
My 99 coupe has recently developed an oil leak. ....
Ouch thats what I think I have
Old Jan 24, 2009 | 04:45 PM
Bill Dearborn's Avatar
Bill Dearborn
It could also be a power steering leak. Check the pump, hoses and rack.
Bill
Old Jan 24, 2009 | 04:53 PM
Vette19's Avatar
Vette19
Don't forget about the oil sending unit ! They are horrible about going bad. Cheap and easy fix.
Old Jan 25, 2009 | 07:02 PM
LIGHTNING's Avatar
LIGHTNING
curious....where is it located?
Old Jan 25, 2009 | 08:58 PM
Vette19's Avatar
Vette19
Top of engine, rear of intake manifold.Many threads here about them and how to replace.They are cheap and cause a range of problems from bad oil pressure readings to leaks. Mine did both .Leaks down around rear of engine,like a bad rear main.Sometimes smokes because it leaks onto manifold.
To Oil leak, ideas?
