crank pinning kit
Jan 24, 2009 | 09:16 PM
crank pinning kit
Does anyone have a crank pinning kit the would let me use for a small fee
Jan 25, 2009 | 04:45 PM
Do you need just the guide that goes on the bolt? I have that but I don't have any of the pins needed to pin the crank.
Jan 25, 2009 | 05:05 PM
Quote:
Originally Posted by
Ilovechevymusclecars
I just need the guide; As of right now, I supposivly have a member sending me one, I'm just waiting to received his shipping confirmation.
Jan 25, 2009 | 05:15 PM
There are two types of pinning kits.
The ATI kit pins the damper using the key-way in an aftermarket damper by inserting a pin perpendicular to the crank.
The second type inserts a pin along the axis of the crank AFTER the damper is installed – no damper keyway required.
See the links below
http://forums.corvetteforum.com/c5-t...k-pinning.html
See photos in POST #30 (for the ATI type) in the thread below -
http://forums.corvetteforum.com/c5-f...f-with-eg.html
Jan 25, 2009 | 06:14 PM
It's definitely the 1st one. It is a stock crank
