Brake Fluid Sensor
Old Jan 29, 2009 | 03:36 PM
vetteguy0483's Avatar
vetteguy0483
Default Help!! Brake Fluid Sensor
My brake fluid sensor went out on my 02 and I got the new one but I cant figure out how to change it. Do I need to drain the master cylinder?
Old Jan 29, 2009 | 07:40 PM
vetteguy0483
anyone?
Old Jan 29, 2009 | 07:55 PM
AllVette's Avatar
AllVette
From the Service Manual:
Removal
1. Disconnect the electrical connector from brake fluid level sensor.
2. Remove the brake fluid level sensor. Using needle nose pliers, carefully depress the retaining tabs on the end of the brake fluid level sensor and press the sensor through the reservoir to remove.
Installation
1. Place the brake fluid level sensor into the reservoir, press into place to secure the sensor retaining tabs.
2. Connect the electrical connector to the brake fluid level sensor.
Old Jan 29, 2009 | 08:27 PM
vetteguy0483
wow.
ok thank you very much.
To Brake Fluid Sensor
