Need help with window problems.
Old Jan 29, 2009 | 10:40 PM
wingnutphil's Avatar
wingnutphil
Default Need help with window problems.
I have a 99 C5, the passenger door window and lock doesn't work while the door is closed. If I open the door everything works. I have the door apart but I can't find the problem. Any ideas?
Phil
Old Jan 29, 2009 | 11:11 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Got to say that's a new one. Well, start by opening up the accordian tube in the door jam area and look for anything suspect in there...especially shorting wires to the frame.
Old Jan 30, 2009 | 05:08 PM
a4troy's Avatar
a4troy
start w/wiring diagram helps to know what you are looking at first.
Old Jan 30, 2009 | 06:42 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
COMMON ISSUE!! Pop out the accordion tube from the door and door frame, pull out the harness from the hole in the drro frame and examine the harness connectors. On one you will see a clear sheaf wire thats going to be pulled out of the sheaf. Cover that wire with tape or better yet, liquid electrical tape. That should solve that issue. Now,, do the other door too!
BC
Old Jan 30, 2009 | 07:50 PM
Bakersfield's Avatar
Bakersfield
Bill is right. This may help too.
http://forums.corvetteforum.com/c5-g...w-problem.html
Old Feb 13, 2009 | 04:53 PM
wingnutphil
Default Thanks
I finally found the time to pull the door apart. I found the problem right where you guys said it would be. Thanks for the help.
To Need help with window problems.
