Help with shifter
Old Jan 30, 2009 | 08:46 PM
71corv's Avatar
71corv
St. Jude Donor '08
Default Help with shifter
Took the existing shifter out of my ZO6 today to install the MGW shifter.When I pulled the existing shifter out I heard something drop that sounded like a piece of metal. Searched with a light and a long magnet but did not find anything. Any ideas on what happened? Thanks,
Gene
Old Jan 30, 2009 | 09:17 PM
bartsky's Avatar
bartsky
Maybe the alignment pin?
Old Jan 31, 2009 | 12:11 AM
dataporter's Avatar
dataporter
I know I've done it. I finally got mine out with a magnet on a flexible rod, but I was prepared to leave it in there. It is an L shaped piece of rod about a quarter inch on the lower part of the L and inch and a half maybe long about the diameter of a 8d nail...
Old Jan 31, 2009 | 02:39 AM
LoneStarFRC's Avatar
LoneStarFRC
That's what I was thinking as well. BTW, it is exactly 1/8" in diameter so if you don't have the OEM pin and need to use it, a 1/8" drill bit works perfectly.
HTH
Old Jan 31, 2009 | 12:09 PM
Patches's Avatar
Patches
To get stuff I've dropped in the tunnel, I've driven up/down my steep driveway and slammed on the brakes. Usually works.
Old Jan 31, 2009 | 02:49 PM
LoneStarFRC
I'm trying to picture the look on your neighbor's faces while that's going on.
Old Jan 31, 2009 | 05:32 PM
Hrdtop00's Avatar
Hrdtop00
Gene
Gene,
I feel your pain! I dropped a socket when installing my headers & had a h*** of a time figuring out if I could find it! Speaking of headers, how do you like yours?
Wayne
Old Jan 31, 2009 | 05:36 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Heres a picture of the pin just incase your interested.
The pin in this picture is inserted into the alignment hole to check the alignment.
When you pull the pin UP, it sets in the TOP of the grove and is disengaged from the shaft.
I agree,,,thats what probably fell out. Make sure you use the new shifter fasteners that came with your new shifter. The OEM ones will be TOO short to properly secure the shifter on the box.
BC
Bill
Old Jan 31, 2009 | 09:20 PM
71corv's Avatar
71corv
St. Jude Donor '08
Thanks to all for the help. Have to agree that the pin is what came loose. Have used the magnet on the flexible rod but didn't latch on to anything. Drove the car several times and guess I will take the new shifter out and see if I can find the pin now.
Wayne, really enjoy the headers when I'm by myself. Have to stay out of the throttle when I have the right seat occupied.
Again, thanks to all for the help.
Gene
Old Jan 31, 2009 | 11:42 PM
c5blkvetteguy's Avatar
c5blkvetteguy
I put a hurst shifter in my car and I dont remember a pin being there. Could this be why I have shifting issues? What should I do?
Old Feb 1, 2009 | 08:27 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
That L shaped pin is only there to lock the shifter in Neutral which allows you to loosen the shift shaft and put the trans in Neutral. Once you have that neutral reference with the shifter and trans, tighten the coupler nut and your done.
That pin doesn't need to be there any more. I have an aftermarket shifter ( KIRBAN ) and theres no where to store that pin like on a stock shifter. I RTV'ed mine to the tunnel so I wont lose it.
BC
Old Feb 1, 2009 | 10:31 AM
Patches's Avatar
Patches
You can use any small pin/rod that fits in the hole to lock the shifter in neutral if you've lost your original pin. Place the shifter in neutral and slide the pin in (you may have to jiggle the shifter to get it to slide in) so you can center the shifter shaft and then tighten the coupler. Puul the pin out to free the shifter and make it operational.
To Help with shifter
