The few surprises/challenges I encountered in my change were:
Steering rack would not slip out between frame and crossmember. I had to loosen the crossmember to get it out.
Torque required to loosen the harmonic balancer bolt was significant. My old 1/2" impact would not loosen it at 175 psi. I had to upgrade to an IR 2131 with 600 lb/feet.
Use a good puller on the balancer, with a socket or puller insert for the crankshaft to prevent scarring of the crankshaft end.
I had a scare trying to get the lifters up in their bores to be able to get the cam out. It took a few fooseball-like flicks of the wrist to get all of them to pop up high enough.
It takes creative use of bungee cords (or a buddy) to get the AC condenser out of the way (without disconnection) for cam removal/install clearance. Tape some cardboard on the condenser for protection.
Hey Eric, thanks for the link! Its amazing how much redundant unnessisary crap is in that article, but it does show the extra front suspension/steering tasks I'd have to do. Doesnt look like too big of a deal.
C5Tweaker, you can just leave the crank pulley bolt in and let the puller press against that. No need to shield the crankshaft end from the puller with the bolt in there (but mostly unthreaded).
Also, FYI, after my 5th cam swap, the "foosball" method didnt work any more and I had to buy some retractable magnets to hold the lifters up. DOH.
Check out my site and look at the head swap document...I put LOADS of pics up of the LS1 with the heads off, and what you need to do to do the swap. http://ls1.fbody.com
Thanks Ryhs....I'm buying a C5 in the next two weeks and guess what the first mod is, taking the heads off my SS (NOT A T/A!) and putting them on the C5. I'll note any differences between the two on that webpage for others to use.
Its the same dang engine though so the engine stuff will pretty much be the same reguardless.
Outstanding piece of work! I don't know what you do for a living, but I hope you are writing training materials for mechanics. Made me want to go rip into my new Vette and see my wife's jaw drop and her face go pale, again. :eek:
Video games??? Anyway, you did an outstanding job with that presentation. HMM, how about using computer animation on the next one? Little screws backing out, animated antifreeze dropping onto the garage floor, blood flowing from the knuckles..I'm sure you get the idea. It's late I'm at work and it's time to get out of here. :smash:
It would absolutely be very appreciated if you did that again on a C5 with the amount of detail you already did on the SS. :cheers:
