Odd electrical problems...not grounds...
) The car started behaving better, so I didnt think about it again...until today.
Taking off from a stopsign, I had the car just quit running right. In fact, it barely ran at all, at like 300 RPM (with a big cam) like it was out of fuel pressure. Hitting the gas did NOTHING. I restarted a dozen times with no improvement. So I pulled it over and started pulling codes.
P0461H
P1431H
P1518HC
C1278
U1000H
B2265H
U1016H
U1064H
After a call to a buddy of mine, I tried to start it, and what do you know, it runs fine again
However, now I have a steady check engine light (that didnt even go away after disconnecting the battery). I did notice that the alt voltage after starting it was a little low (12.8v) but now it cycles again between 13 and 14v like normal, like nothing ever happened since I disconnected the battery.Anybody ever experience this kind of problem before? I'm assuming it's also related to my starting issue since it took 3 twists of the key before it would crank...every so often, the car wont crank, I will need to jump power to the starter solenoid then it works fine. Usually happens after sitting overnight but occasionally happens hot too.
Grounds were just cleaned a week ago. Memory still has a mind of its own among other small electrical gremlins I just cant pinpoint!
Car is a '98, 172k miles, M6. Just got a dynotune and an LS6 intake last week if it matters.
Sidenote
Mileage sucks now
I think it's due for 02 sensors.
Find my post on " C5 IGNITION SWITCH REPAIR" and carry that procedure out. You will think you have a different car!
That many miles on the car, your ignition switch is very suspect!
Find the post and see what you think.
BC
drove it home. Short story after 3 weeks of going nuts. My positive battery cable had corrosion inside the red cover you could not see. At the starter the battery cable looked ok but the small 16ga wire connector that goes back to the ignition had been eaten through. Changed positive cable and fixed connector and I'm fine.PS, found a guy near me that will rebuild sileniod for $75.00 same day service. Cheaper than new starter.
Letcha guys know what I find out.
I would look there first, and follow Bill Curlee's write up.
If you have an active CEL there should be a DTC asscoiated with it. If you clear that DTC the CEL should go out. If the DTC is C or CURRENT, the CEL will not go out. If it is a H or history DTC it should clear and the CEL shoud go out. Disconnecting the battery can and will cause random DTCs to pop up.
Bill
Good news is I pulled out my ignition switch this weekend, and whaddya know, 2 burnt contacts. Some cleaning and minor bending and she looks and feels like new now. I'll ride that out and see if the problem goes away. So far so good!
I also too the opportunity to install my new 2 tone shift boot/****, e-brake boot and handle and console lid cover from leatherseats.com that I had waiting to go in
As well as new O2 sensors. hwy mileage is fine now.After that my A/C light would come back on when the button was pushed, but it still doesnt blow cold. I have yet to figure that out.
I did pull apart the other half of the switch (PITA) and greased the cam in there. If you pull it apartm you need to be careful though or the detent pins can fall out! They are TINY.
