whats a catch can for?
Old Feb 8, 2009 | 10:52 AM
David426's Avatar
David426
Default whats a catch can for?
What does a catch can do and whats it for? Do i need one?
Old Feb 8, 2009 | 11:38 AM
hotwheels57's Avatar
hotwheels57
There's lots of past debates, some very heated, about the pros/cons of the catch can use on an LSx motor.
Some say you don't need it or GM would have put them there. Some say you don't need any oil in your intake. That latter was my justification to install one. I check it every oil change and find a small amount trapped in the can.
Use "catch can" in C5 Tech as the keywords. You can use search or search this forum in the red banner...
Old Feb 8, 2009 | 11:46 AM
timemender's Avatar
timemender
Usually means catching stuff in a can.
I crack myself up.
LSx engines benefit from placing a catch can in the PCV system to remove oil (and depositing it in said can) from the PCV air stream before it enters the intake manifold.
Old Feb 8, 2009 | 07:33 PM
ZO6ME's Avatar
ZO6ME
It works. Had mine on for 2,000 miles and sure enough there's oil in it.
Old Feb 8, 2009 | 07:37 PM
csexton's Avatar
csexton
Just put mine on a couple of weeks ago.
Chuck
Old Feb 8, 2009 | 07:53 PM
lucky131969's Avatar
lucky131969
Ok, you've peaked my curiosity. Who says you need oil in your intake?
Old Feb 8, 2009 | 08:23 PM
Mike94ZLT1's Avatar
Mike94ZLT1
It needs to be lubricated so the air can flow through it smoothly. Duh
Old Feb 8, 2009 | 08:26 PM
lucky131969
Damn, I should have known that
Old Feb 8, 2009 | 08:31 PM
Dave68's Avatar
Dave68
http://www.conceptualpolymer.com/PCV...oval%20102.pdf
This should fill you in....
Old Feb 9, 2009 | 09:32 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
A few weeks ago, I cleaned my air filter (Vararam) and pulled my throttle body off to clean it also. I looked inside the black intake manifold and found a small puddle of oil (silver dollar sized) right after the intake opening. Is that what the catch can is supposed to get rid of ?
Toque
Old Feb 9, 2009 | 09:55 AM
Toque's Avatar
Toque
Toque
Guys:
Answered my own question with some searches on here. Looks like I'm adding a catch can. Maybe a Father's day present from my wife/son...
I was wondering what that oil was doing in my intake... .
Toque
Old Feb 9, 2009 | 11:58 AM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
Guys:
Toque
The term "catch can" is a misnomer, at least in its application here.
Think more in terms of "oil separator" and you'll be on the right track. Check LPE's website -they have one of the finest, most cost effective solutions going.
Old Feb 10, 2009 | 05:37 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Keeps this
from going back into your manifold
Peace
Chip
__________________
..................Click for
Old Feb 11, 2009 | 06:16 AM
dieseldave56's Avatar
dieseldave56
Default cause and effect................
First off if you have a LSx engine you need a oil catch can/ tank i.e. oil seperator for the oil vapor that is emitted from your PVC / crankcase.
The PVC system is closed so that this nasty, oily , water moisture vapor is routed back into the combustion chamber . That's where the fun begins.
This contaminated air fouls the throttle body and MAF sensor causing malfunction or failure.
It will mess up the air /fuel mixture ratio which will cause detenation,then the EMC to retard the timing and reduce power.
Excessive carbon build-up or better think of charcoal bricketts on valves , pistons , ring lands, combustion chambers and spark plugs.
Also this contaminated oil will foul and plug up the CATs and O2 sensors which will increase emissions .
All the above will also eliminate the need for you to carry a wallet, cause you won't have any money left after the repairs.
http://forums.corvetteforum.com/newr...1&p=1568895720
http://www.customcorvetteaccessories...lcatchcan.html
Old Feb 11, 2009 | 08:14 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I have seen several different versions of the catch can installed. It does intrigue me what the difference is in them. I have seen an moisture separator installed and working as a catch can. This seems to be a very cost effective solution to the problem. A couple of weeks ago I installed new water pump seals on my Z and noticed the oil in my intake. I knew when I saw this I needed to pursue the catch can installation.
Old Feb 11, 2009 | 11:44 PM
TNX ZORA's Avatar
TNX ZORA
It may be difficult to quantify but how much worse is this oil-in-intake problem in a racing environment compared to street? Let's say on a scale of 1 to 10. Does it get noticeably worse as an engine wears and blowby increases?
Old Feb 12, 2009 | 05:33 AM
dieseldave56
Default oil consumption for the LSx
Tracking your Vette . You are advised by GM to ADD one additional quart of engine lubricant to compensate for the predictable oil consumption.
Understand the cause of this blow-by as explained by GM i.e.http://www.rjsmith.com/gm-894549.html
This issue was explained by Dave Hill , Chief Corvette Engineer and John Juriga, Asst Chief Engineer of the Gen 3 engines back in 2002. Driving style, aggressive driving style where high engine speed along with low or no engine load caused piston ring flutter that allowed crankcase oil blow-by.
Well, that's true to a point. It goes deeper. Starting with the 1997 LS1 and then the LS6 Gen 3 (5300) aluminum block has issues with the siamesed cylinder bores ( except the last 20mm) and the limited coolant passages between them. This limited cooling area causes hot spots in the upper areas of the bore that causes distortion both in diameter and bore taper. Gm's machining tolerances for the cylinder bores were also not as tight as it now appears they should have been.
Take that scenerio then add the very thin (at 1.5mm ) flat face piston racing rings with nine (9) pounds of tension ( low tension for less friction). With the condition of the cylinder bores , the rings were taxed to control blow by, particularly when the driving style , as described by Dave Hill came into play.
GM engineers could not determine the acutal problem till the LS6 hit production with its high rpm operating range. The problem became more pronounced. So Bulletin #894549 came to be. The fix was to replace the top piston ring in owners cars that met the criteria with a higher (13 pound ) tension ring with a Napier scaper face. That appeased some of the owners. * Note a new larger diameter piston with a new anti friction polymer was introduced to the 2001 M/Y production line in mid April 2001. This was to address complaints about the 'cold start slap' . This new piston decreased the piston to wall dimension and may have helped the OEM piston rings as well.
With the introduction of the LS6, the PVC oil baffle /oil seperator was placed under the new intake manifold for less exposure to oil vapor.
A new piston ring pack , with the same criteria was introduced to the 2002 M/Y production line, along with the new cold start piston. Oil issues still remain. Engine reliability has never been an issue.
The oil consumption varies widely from car to car and owner to owner. I have three C5s, two (2) 2000 FRC and the 2001 Z06 and all use about the same oil, half quart between 3000 mile oil changes. Note * all the cars have 25,000 or less miles and are not DD. Also all have the LS6 PVC system.
As to will the oil consumption increase with miles , I have not read anyone that complained of that. But reality is that wear will cause increased blow-by but at an accelerated rate, which is what I believe you were refering to.
The LS2 has a new Gen 4 block that addressed the issues of cylinder bore tolerances and cooling. The LS2 uses piston rings still use the Napier face but are thinner (1.2mm) and has less over all tension than the 2001 LS6 does ( so much for those that faulted the piston ring tension alone). Plus the LS2 has PVC oil baffles or seperators at both fresh air inlet and fouled air outlet. Go to the C6 topic area and you will find that they also have oil issues and discuss the installation of oil catch cans or air/oil and condensation seperators.
Many auto manufactures have OEM catch cans, particularly turbo or supercharged cars. Hope this helps . DD
Old Feb 15, 2009 | 12:16 AM
TNX ZORA's Avatar
TNX ZORA
Thank you for your excellent reply, dieseldave56!
To whats a catch can for?
