fuel gage problem
Old Feb 9, 2009 | 12:28 PM
mebowman's Avatar
mebowman
2nd Gear
Default fuel gage problem
98 c-5 fuel gage goes to full then to empty when starting eng. need help to fix.
Old Feb 9, 2009 | 12:36 PM
ROJO99's Avatar
ROJO99
Sounds like a normal gauge sweep when alot of power is drawn, like when the starter is engaged. Is the gauge going to zero when you drive? The gauge going to zero when driving and the tank being full has happend to many people. It is usually a fuel additive issue. Happend to me in Fla and I ran a few tanks of fuel injector cleaner and have not had problems since.
Old Feb 9, 2009 | 12:41 PM
tomurphjr's Avatar
tomurphjr
If it drops to empty out of the blue while driving you need to get some Techron fuel additive. It helps a lot with the issue.
Old Feb 9, 2009 | 01:04 PM
BCC5's Avatar
BCC5
Default Does the Techron work if...
Sorry to jump in this thread but I am having a similar problem with my 99. Full down to 1/4 all works fine. Then when it hits 1/4 it drops to empty. This seems to only happen when on the highway. Will the Techron additive help?
thanks
Old Feb 9, 2009 | 01:38 PM
87SAM's Avatar
87SAM
If the problem is due to dirty sensors, Techron will help. It is not an over night cure, may take a couple of tanks or more. When I had the gauge problem, I added a bottle to one tank fill and then started using Chevron gas at subsequent fill ups, in a month the problem went away.
Old Feb 9, 2009 | 10:06 PM
vettandtyphoon1's Avatar
vettandtyphoon1
TECHRON it worked on mine to the point... GET IT autozone
Old Feb 9, 2009 | 11:12 PM
BCC5's Avatar
BCC5
Old Feb 9, 2009 | 11:28 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
There is a firmware update available as well that shows this issue. Although the update is supposedly fuel curve information, I was having the same issue on my '99. Used the Techron and it would be Ok for a while, then come back. I had the updates put in, no more problems with the tank going to zero. Your guess is as good as mine.
Old Feb 10, 2009 | 12:43 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Techron and time! Cures most problems like this.
Bill
Old Feb 10, 2009 | 07:59 AM
oakvillec5's Avatar
oakvillec5
Techron is usually the cure...be patient, although my similiar problem went away within a few KMS of the Techron application.
Old Feb 10, 2009 | 08:22 AM
mebowman's Avatar
mebowman
2nd Gear
Thanks corvette lovers, you have to love a vette to put up with it. Just kidding!!!!!!!!! I have had several from 1957 to 2009 . I SOLD MY XK 140 IN 1957 AND BOUGHT A BLACK 1957 VETTE A GREAT AUTO CROSS CAR. I HAD TO CHANGE A FEW PARTS, PUT ON SLICKS AND WORK ON THE FI. I NOW HAVE A 1998. THANKS AGAIN. MAX B.
To fuel gage problem
