Uneven Ride Height
Could it be that the front leaf is not centered in it's mounts, thus causing one side to sit higher? I wouldn't mind 1/4" or so, but 3/4 is unacceptable, and I don't want to have to crank the heck out of one adjuster to even get them to within 1/2".
Opinions? Thanks in advance.
IMO I would adjust the bolts until you are satisfied.
Good luck.
Measuring from the fenders, with both bolts bottomed for minimum ride height, the right side sits 3/4" lower than the left at 26 1/4". I've twisted the right adjuster and gotten it up to about 26 1/2", but the car now seems to ever-so-slightly want to turn to the left. I would imagine that's the preloading of the spring from the adjuster that's causing the behavior.
My theory was that the leaf spring wasn't perfectly-centered, and I was wondering if anyone else had experience with such an issue. Guess I'll climb underneath and measure the best I can to check on the spring centering. I would think that could have an effect on ride height irregularities.
Thanks for the replies and any other words of wisdom.
Perhaps an adjustable end-links will help and then you can try and lower it more.
By measuring at the control arm bolts, you're setting the actual height of the CHASSIS, and not the body panels, which are NOT adjustable, and may vary from side to side. This may not give you equal "fender gap", but it does give you an accurate, and lower, chassis height, which is more important.
Secondly, when levelling the chassis in this manner, it automatically takes the sway bar links out of the equation, as the chassis will be level, and not inputting any tension into the bars.
Also, to the OP, did you drive the car a bit after making the adjustments? This topic has been discussed MANY times, and most people agree that anywhere from 40-70 miles are sometimes needed to get the car to "settle" after adjusting the spring bolts.
Good luck!
I believe, however, those "J" and "K" figures are from the center of the lower control arm pivot points....
a 79 cent 3" turn buckle and bolt, but it works good.
My 2000 shop manual has specs of J=6.02" (front) and K=6.22" (rear).
These are measured from a point on the lower edge of the rocker panel 35 inches behind the center of the front wheel, and 31 inches in front of the center of the rear wheel.
I assume they are referring to the painted fiberglass rocker panel, and not the frame. Seems strange, as the rocker panel could probably vary quite a bit in it's distance from the frame, depending on how it's molded and bolted on?
Then there is Z ht, which is the distance between the lowest point on the lower ball joint and the center of the front of the inner lower control arm bolt = 1.73". Looks difficult to measure without proper leveling equipment. But seems more accurate than that "rocker panel" stuff.
There is a similar D ht = 4.25" for the rear. Measured from the same points (lower ball joint to control arm bolt).
I guess you could put a level across the bottom of the ball joint, pointed toward the front of the control arm bolt, then measure straight up from the level to the center of the bolt, and you should be at 1.73" or 4.25".
Whew!
DG
To those who asked, I forgot to mention that I did measure between the frame and the ground near the lift points, and the right sits still sits 1/4" lower than the left. Is the only way to level the car with the adjusters, or is there something else I can tweak? Nobody has said whether or not an un-centered spring could cause this. I'm still curious.
Thanks everyone for the thoughts. Keep 'em coming!
Any news yet?
So it is important to measure and adjust the right height by measuring to the lower part of the frame where the A-arm attaches front and rear. and the Rear should be 1/4 to 3/8" higher then the front.
Ideally this should be measured with the drivers wt is in the drivers seat.
Good Luck
Then measure from the frame
