Having some problems need HELP!!!
Old Feb 20, 2009 | 04:42 PM
jetstreamC5's Avatar
jetstreamC5
Default Having some problems need HELP!!!
So I took my car out lastnight and when I got home and was pulling in the driveway I heard this crackle sound thrue my speakers lights got dem guages went crazy then every thing come back up and the service
active handling, abs, and ride controll came across the screen.
So I turn the car off for a minute then start it back up take it around the block and every thing is fine. Get in it today take it to the store get back home still fine. So then I go to pick my girlfriend up and it starts doing the same thing so I try to get it back home get almost there and it just dies I let it sit a min just turn the key on to see what it says and it says ( Take key out wait 10 sec) so I did start it back up take it home and its fine again.
Can anyone help me tell me where to start?
Thanks,
Michael
Old Feb 20, 2009 | 04:52 PM
jetstreamC5
Also when car is runing volts guage is reading anywhere from 11.0 to 14.5.
Old Feb 20, 2009 | 05:03 PM
Point & Shoot's Avatar
Point & Shoot
Check the battery cables to make sure they are not corroded and tight.
Check to make sure the battery isn't weak.
Check the main ground connections under the hood that bolt to the frame rails just behind the headlight motors.
Read the sticky post at the top by Bill Curlee called "Electrical Information" for other things to check.
Good luck.
Old Feb 20, 2009 | 05:07 PM
jetstreamC5
Good luck.
Thanks!
Old Feb 20, 2009 | 07:13 PM
bluvette79's Avatar
bluvette79
i would guess loose/dirty battery connection and/or battery bad first. i don't think you should ever see below 12v on the dic. if you have an ohm meter, check across the battery. it should be at least 12v with car off.
Old Feb 20, 2009 | 09:00 PM
Ragtop99's Avatar
Ragtop99
Check the alternator as well with the car running it should never be 11v. My runs between 13.5-14V
Old Feb 20, 2009 | 09:58 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Bill Curlee found a problem with a possible shorting wire inside the door-jam accordian tube areas. That will cause all sorts of problems. Have you pulled your codes yet?
Old Feb 20, 2009 | 10:01 PM
ghostdog234562003's Avatar
ghostdog234562003
Check positive terminal of the battery. Sounds like a short somewhere...
Old Feb 21, 2009 | 12:25 AM
jetstreamC5
Thanks guys for the help but I think I got it fixed I checked the grounds and they were a little coroded so I cleaned them and put everything back together drove it all night no problems yet!
Old Feb 21, 2009 | 07:49 AM
rws.1's Avatar
rws.1
bad grounds can bring the C5 to a standstill....
To Having some problems need HELP!!!
