daytime driving lights
Old Feb 21, 2009 | 08:42 PM
KRZ06's Avatar
KRZ06
Default daytime driving lights
I have an 01 Z black w/blackout kit and I would like to disable or turn off these lights. Can anyone help with a solution short of leaving your E brake on the first notch.
Old Feb 21, 2009 | 11:15 PM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Pull the number two fuse under the hood. It will disable the lights. It's called the approach fuse. It also will disable the reverse lights that come on when you unlock the car at night. No big deal.
Old Feb 22, 2009 | 06:32 AM
DeeGee's Avatar
DeeGee
As Camjamsdad says the easiest way is to pull the A2 fuse.
If you want a more permanent fix and to retain the approach lights functions you can do the relay mod. Here's how:
https://www.corvetteforum.com/techti...=273&TopicID=1
Old Feb 22, 2009 | 10:06 AM
bluvette79's Avatar
bluvette79
cant you turn them of in the dic program?
Old Feb 22, 2009 | 01:19 PM
KRZ06's Avatar
KRZ06
Simple enough, thanks for the help approach lights are no big deal.
Old Feb 23, 2009 | 12:20 AM
Camjamsdad's Avatar
Camjamsdad
St. Jude Donor '13
No, The DIC lists that as an option but it doesn't knock out the DRL's.
To daytime driving lights
