exhaust
Old Mar 2, 2009 | 02:31 PM
spdracr39's Avatar
spdracr39
Default exhaust
will c6 z06 exhaust fit (bolt on) a c5 or does it require a lot of fabrication work?
Old Mar 2, 2009 | 02:38 PM
J S Machine's Avatar
J S Machine
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17
St. Jude Knife Maker
Cat back TI's bolt right up. Is this what you are talking about?
Old Mar 2, 2009 | 04:18 PM
byronhunter's Avatar
byronhunter
NO, an yes, lots of almost impossible!
Old Mar 2, 2009 | 05:09 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
They are two very different BEASTS when it come to the exhaust of the C6 vs. the C5!
It is way better to buy a aftermarket set of catback exhaust then to try to fab the C6 Z06's exhaust to the C5 - I'm sure it can be done but it will require some good welding and time and then in the long run you would of been better off getting one specifically designed for the C5
Hope this helps some
Thanks,Matt
Old Mar 2, 2009 | 10:30 PM
spdracr39's Avatar
spdracr39
I have a friend that is going to upgrade his c6 and was going to give me his takeoffs if they would fit but i figured they would not because they look a lot different and I couldn't be that lucky. Thanks for the help !!
Old Mar 3, 2009 | 07:51 AM
J S Machine
Sorry man, I misread your original post and thought you said C5 Z06 exhaust. My appologies.
No they won't fit without modding for the correct answer
Old Mar 3, 2009 | 08:41 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The C6 does NOT have the deep center well area that our C5 has. The C6 exhaust system runs right down the center of the car and straight out the back. You would have to eliminate that well area to start.
To exhaust
