Valve Covers Cracking???
Old Mar 3, 2009 | 10:15 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
Default Valve Covers Cracking???
Don't know if this belongs here or the general section, but.....
Was doing some cleaning today and noticed my valve covers have what appear to be cracks around the coil retainer holes. Does anyone know if this is a problem with the LS1 or just mine? Seems to be more dirt/oil residue around that area as well. Does anyone else have this problem?
Do these look like cracks to you??
Before cleaning...
After cleaning. Can you see what I'm talking about?
Do I need new valve covers?
Old Mar 3, 2009 | 10:29 PM
nastymant's Avatar
nastymant
no, i believe those are just casting marks...i think you are good to go
Old Mar 4, 2009 | 05:40 AM
vettenuts's Avatar
vettenuts
There are a lot of imperfections in the castings. I attempted to polish mine last winter and gave up because the imperfections were too bad and throughout the casting.
Old Mar 4, 2009 | 07:48 AM
vsocks1's Avatar
vsocks1
They do not look like casting marks to me - wait and see what happens after some more miles. If oil residue shows up they could be small cracks.
Old Mar 4, 2009 | 10:50 AM
itzza427's Avatar
itzza427
I think it looks more like a casting flaw than a casting mark. I agree with the wait and watch as well. Doesn't appear to be a real problem as that build up probably took years to form.I wouldn't worry about it unless it's one of those things that just bug you 'cause you know it's there!!
Old Mar 4, 2009 | 10:56 AM
LoneStarFRC's Avatar
LoneStarFRC
No.
btw, I noticed your EOP sensor relocate. Nice.
Old Mar 4, 2009 | 01:30 PM
c5blkvetteguy's Avatar
c5blkvetteguy
Mine are the same way! Been like that for years. I cleaned the valve covers up and no leaking.
Old Mar 4, 2009 | 01:43 PM
wcsinx's Avatar
wcsinx
Saw the same thing on mine when I cleaned them off. Inspection under magnification confirmed they are indeed casting flaws and not cracks. The inner surface was perfectly smooth.
Old Mar 5, 2009 | 12:36 AM
happiedazs's Avatar
happiedazs
If I had those I'd fill them in with JB Weld of some type of epoxy just to make sure
Old Mar 5, 2009 | 07:44 AM
vsocks1's Avatar
vsocks1
I would be upgrading to some new ones myself! Maybe I am just too picky but it would bother me!
Old Mar 5, 2009 | 08:34 AM
wcsinx's Avatar
wcsinx
There is no filling as at least on mine they were ridges and not valleys. I could've ground them off, but good lord who gives a chit? Once the coil packs and rail covers are on, you have 0 chance of seeing them.
Old Mar 5, 2009 | 08:49 AM
SilentFright's Avatar
SilentFright
From: Arlington Texas, originally from San Angelo, TX
They have been on every set of OEM LSX valve covers I have ever seen. They are casting flaws.
Old Mar 5, 2009 | 02:42 PM
mstromquist
Thanks guys. It does bother me a little to know that they are there, but on the other note, it is under the covers and coils. So just to make sure, I am going to look at them a little closer this next weekend just to make sure for my own piece of mind. A little magnification and some dye pen should do the trick. Appreciate the comments everyone.
Old Mar 6, 2009 | 01:59 PM
blue63cpe's Avatar
blue63cpe
Welcome to the wonderful world of the low bidder parts. There's no need to use a better alloy or a thicker casting when cheap plastic covers dress the engine bay. GM used plastic valve covers on the lt engines from 93 on. The ls engines also have plastic intakes, tell me fast don't make a tidy profit on thiers. How many pennies does GM make using nylon gears instead of steel on the headlight motors?
Old Mar 6, 2009 | 08:35 PM
LoneStarFRC
Interesting how those original nylon headlight gears on my car have continued to work well for the last 154,000 miles too.
To Valve Covers Cracking???
