check engine light
Old Mar 5, 2009 | 08:05 PM
c5vetteman99's Avatar
c5vetteman99
Default check engine light
hey guys, this weekend i had lg streets installed. i already had a hurricane intake and corsa pace car. i drove the car for about 150 miles and then the check engine light came on. im not sure if its the O2 sensors or if the car is running lean, or anything else. i was wondering if anyone else had this problem and what i should do.
thanks,
tyler
Old Mar 5, 2009 | 08:09 PM
vsocks1's Avatar
vsocks1
First thing you should do is read and post the codes....otherwise we are all just guessing what it could be. Report back!
Old Mar 5, 2009 | 08:16 PM
c5vetteman99
can an advance or auto zone read the code for me?
Old Mar 5, 2009 | 08:19 PM
vsocks1's Avatar
vsocks1
You can read it with the DIC, do a search here or read the user manual!
There are many threads on reading the codes.
Old Mar 5, 2009 | 08:20 PM
tommie's Avatar
tommie
http://www.stengel.net/diccodes.htm
do this and then post the codes...
Old Mar 5, 2009 | 08:40 PM
c5vetteman99
it gives me the cat. that its in but not the actual code
Old Mar 5, 2009 | 08:47 PM
c5vetteman99
28-tcs 1 code
40-bcm no code
58-sdm 1 code
60-ipc no code
80-radio no code
99-hvac no code
ao-lcdm 4 code
a1-rdcm 2 code
a6-scm 2 code
b0-rfa no code
Old Mar 5, 2009 | 09:21 PM
tommie's Avatar
tommie
do it again and look for codes under 10-pcm... they should be the 1st and you should beable to read them when the dic is going through its automatic checks...
Old Mar 5, 2009 | 09:39 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You need to toggel through the codes for each module Use the fuel anf trip buttons to toggle UP & DOWN through the DTCs
BC
Old Mar 6, 2009 | 06:07 PM
grecohead's Avatar
grecohead
i put the lg streets on my 02 automatic. check engine light came on. i checked it with the diablo sport predditor. showed my 02 sensors. i cleared them but they just come back on after 20 mins of driving. if you went with the cat delete you need to get the codes removed with an ls-1 edit from a shop that has that. i just left it alone and drive with my check engine light for now
Old Mar 6, 2009 | 07:42 PM
c5vetteman99
thanks, i kinda thought that it was that. i have talked to a couple guys and they said that there is a "fake" senor that sends the message that everything is fine. im proly. going to get them, if it works ill let you know.
Old Mar 7, 2009 | 05:02 PM
Fasthotrod's Avatar
Fasthotrod
Good luck finding the 'fake' sensors... the company that makes them got hammered by the EPA and almost put them out of business.
They can be 'tuned out' if you know someone with the software, or take your car to a local tuner and have them do it.
Mark
Old Mar 7, 2009 | 05:09 PM
Fasthotrod's Avatar
Fasthotrod
While I'm thinking about it: Did you move the rear O2 Sensors to the front, or did you replace the front O2's and keep the rears in place?
It's all in the paperwork you should have received with the headers: The stock O2 sensors will lose heat from their mounting position compared to the stock manifold, and therefore need a more robust heater like the ones found in the rear style O2 sensors.
When I did my car, I removed all of the O2 sensors, and then installed new 'rear style' O2's in the front locations. I get two codes because of this:
P0140 Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 2
P0160 Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 2 Sensor 2
This is because the computer doesn't 'see' any activity on the rear O2's. This is the part that can be tuned out.
Good luck.
Mark
Old Mar 7, 2009 | 05:28 PM
Fast Cop's Avatar
Fast Cop
I did the LG street's install last week and so far no codes. I did get 2 additional rear 02 sensors so I am running 2 rear up front and 2 rear in the rear and I love the new found power.
Old Mar 8, 2009 | 08:29 AM
c5vetteman99
i call LG and they told me to move the rears to the front, and put new ones on the back? im getting a cam sometime this month and a tune so hopefully they can get rid of it.
To check engine light
