silly electric ground question
Old Mar 8, 2009 | 08:25 AM
gsxrjack's Avatar
gsxrjack
Default silly electric ground question
just wanted to know,,,,what is the better ground....right to the negative connection on the battery or the motor/frame :o
or are they both the same
thanks
jack
Old Mar 8, 2009 | 08:47 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Theoretically,,,,they should all be the same potential. In actually there is some resistance in the wire and at each electrical connection. If you have good clean and tight connections, you should never really notice any difference between the battery, frame or engine.
The absolute best ground would be directly at the battery terminal. Attaching a wire to the battery terminal isn't very practical but you can remove the small black wire on the negative battery cable from ground stud G-104/108, cut the eyelet off of it and solder on three black wires. One of the wires you would solder on another eyelet and reattach it to G-104/108 ground terminal stud. The other two can be used as aux grounds wire that come directly off the battery.
BC
Old Mar 8, 2009 | 11:34 AM
bowtiebubba's Avatar
bowtiebubba
Since this post is about grounds,i would like to ask a question,but dont want to hijack anyones thread.
How many and where are the engine compartment grounds?
Old Mar 8, 2009 | 11:42 AM
byronhunter's Avatar
byronhunter
Old Mar 8, 2009 | 08:07 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Take a look at my post "IMPORTANT ELECTRICAL INFORMATION (LONG) in the stickey section at the top of the C5 Technical section. The grounds are covered in great detail there.
BC
Old Mar 10, 2009 | 02:21 AM
c5blkvetteguy's Avatar
c5blkvetteguy
If you do "the big three" you will not have to worry about getting a good ground.
To silly electric ground question
