C5 Hyperflash with LED's
Old May 18, 2015 | 02:17 AM
  #61
lionelhutz's Avatar
lionelhutz
Originally Posted by T_Vert
disregard, I located the backfeed location and fixed w/ a diode.
Dave
You shouldn't need a diode. Is a bulb in backwards because that will do what you describe.
Old May 18, 2015 | 03:05 AM
  #62
T_Vert's Avatar
T_Vert
Nope they are all oriented properly. I do have euro taillights w/ a euro harness if that matters any. Had to cut a wire at brake pedal per instructions.
Dave
Old May 18, 2015 | 10:15 AM
  #63
lionelhutz's Avatar
lionelhutz
Dave
Yes, I understand how the Euro lights are wired. There is no reason it should cause a backfeed if done properly.
Old May 18, 2015 | 10:51 AM
  #64
T_Vert's Avatar
T_Vert
All I know is that w/ regular bulbs it worked fine and a few others have mentioned the exact same issue w/ euro tails which sent me there first. I noticed if I removed the brake light LEDS then the problem went away. Even w/ 1 brake bulb in the issue occurred. I then wired in a diode and the problem went away. The LEDS only work when oriented one way so I'm assuming they were in right.
Dave
Old May 18, 2015 | 11:23 AM
  #65
lionelhutz's Avatar
lionelhutz
It sounds like crappy bulbs then.
Old May 18, 2015 | 01:33 PM
  #66
T_Vert's Avatar
T_Vert
Perhaps, They have stellar reviews and no real complaints or similar issues so I don't know.
Dave
Old May 28, 2015 | 04:43 PM
  #67
gerry98's Avatar
gerry98
Default Success!
lionelhutz, thanks for all your help on this. I was able to cut, splice and solder a 3 prong flasher and all works well!!
Old Aug 22, 2016 | 02:49 PM
  #68
jmz06's Avatar
jmz06
Sorry to bring up an old thread but does anyone know where to source the GM plugs for this harness to eliminate cutting? I know a few forum vendors get them and make their own harnesses. I can't see paying $70 for a flasher and 2 plugs honestly. I have the flasher but I need to obtain the plugs. I've gotten a ton of weatherpack plugs and even some GM pigtails from I think it was Del City but I cannot recall as it's been years since I've needed them. Anyone have any input? Anyone have a GM part # or casting # of that flasher plug?
Dave
Hi Dave,
I don't know if you still looking for the GM part numbers for both connectors
Female 10 ways 12064769
Male 10 ways 12064770
Terminals female
12064971 Gauge 22-20
12047767 Gauge 18-16
Terminals male
12059894 Gauge 22-20
12047581 Gauge 18-16
and more connectors here > http://terminalsupplyco.com/pdfviewe...tors&page=p063
