Help with Codes
Old Mar 9, 2009 | 09:17 PM
97silver's Avatar
97silver
Default Help with Codes
Question.....I've been getting 3 battery codes - Battery 1 Fault, Battery 2 Fault and +5V Reference Fault.
This is in a 04 -
Can anyone help as to what these mean?
Thanks!!!
Old Mar 9, 2009 | 11:02 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The last time I saw that issue, it was caused by a bad ground. Check the engine block ground on the passengers side of the engine near the starter and the frame ground point G-104/108. It's on the frame right next to the battery. Just follow the small ground cable on the battery terminal right down to the frame. Recommend removing and cleaning them.
BC
