HUD Freaking Out
Old Mar 15, 2009 | 03:40 PM
Jnape's Avatar
Jnape
Default HUD Freaking Out
'04 C5 HUD is going nuts. All elements lit all the time, blinking on off. Brightness control non-op. Sometimes partial operational with some functions working.
I have removed the cluster and the ribbon cable connection at the top of the cluster is tight. No wire damage can be seen. The wires to the dimmer assembly are intact.
Hardware issue? I will put it back together if it is hardware as my AFTERMARKET warranty will cover it.
The dealership wanted 6 hrs. to DIAGNOSE this before any commitment from the insurance......
Thanks,
John
Old Mar 15, 2009 | 03:54 PM
KEvinC12's Avatar
KEvinC12
Thanks,
John
Me too =[ Luckly it fixes it's self everytime, I just turn it off when it dose it :o I got to get it looked at lol
Old Mar 15, 2009 | 04:08 PM
slothy's Avatar
slothy
all grounds clean? any other issues (electrically) with car?
Old Mar 15, 2009 | 04:23 PM
Jnape's Avatar
Jnape
Good question.
Yesterday my right side window would not come down. Turned it off restarted and it worked. I will pull the door accordian and look at those wires. The car has always been garaged and not driven in the rain or had the engine bay washed down....
Other than that no other electrical issues at all.
Thanks,
John
Old Mar 15, 2009 | 08:23 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
condensation in HUD prolly, comes apart easy w/ 4 phillips screws
clean used HUD can be had for about $250, don't let the dealer get it.
Old Mar 15, 2009 | 09:11 PM
Jnape's Avatar
Jnape
Condensation in the projector or is the HUD portion of the cluster replaceable?
John
Old Mar 15, 2009 | 09:18 PM
SteveDoten's Avatar
SteveDoten
disregard my previous post, I'm going to speculate the 11 pin HUD harness on your cluster is loose, check to make sure both ends are securely installed, runs from HUD switch to back of cluster
I have seen this before
Old Mar 15, 2009 | 09:33 PM
Jnape's Avatar
Jnape
I was hopin so Steve,
All 3 ribons were secure and no visible sign of a wire out of the connectors. I might swap either cluster or projector from my '02Z to see which one it is
John
Old Mar 21, 2009 | 03:03 PM
Jnape's Avatar
Jnape
Well I swaped out the cluster from my 02Z into the vert and same malfunction. I guess it just leaves the projector.....
John
Old Mar 22, 2009 | 03:17 AM
DeeGee's Avatar
DeeGee
Thanks,
John
Sorry if I'm teaching you to suck eggs John but its worth checking
Does this occur at the same time in the same position?
The HUD is a lens that projects the parametric info onto the screen. If the sun is at a specific angle it can hit the lens in such a way that it displays all the symbology at once. The appearance is to flood out the display. Once you move away from that heading the sun no longer reflects and it reverts to normal.
I'd see it on one particular road in Vegas at the same time every day.
If thats not it I'd leave it to the dealer if I had extended warranty.
Old Mar 22, 2009 | 10:30 AM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Happened to me on the way home one night. The sun behind was me and all of a sudden every part of the HUD display lit up at once. I was
As soon as I changed direction it went back to normal. I thought the entire car had fubared at one time.
Old Mar 22, 2009 | 01:51 PM
Jnape's Avatar
Jnape
This thing uses all or partial pieces of the display at random. top half of the speed, no tach and such.
I did have the dealer look at it when they were putting in a new fuel pump. They wanted me to agree to 9 hours of diagnostics. My after market warranty wants to PROVE point of failure. No WAY...
I fought them for a month to do the fuel pump. Had to have the car towed 3 times They wanted the dealer to prove it was the fuel pump. It would blow fuses when hot and ON THE GAS. THEY SUCK.
At least those Bastards had to pay the dealer $1896.00 for the fuel pump
Old Mar 23, 2009 | 02:32 AM
DeeGee's Avatar
DeeGee
That sucks. I guess changing companies would be hard at this stage? Hope you fix the snag
To HUD Freaking Out
