DTE trans strut rod tightening
I marked everything. but the marks wiped off after i cleaned off some trans fluid/.
so, I need to know how to properly tighten just one rod. Since the coating chiped where I used a wrench on the flats. I want to remove it completey and re-coat it . I want to make sure its installed correctly
I have e-mailed Phil,, but I thought someone may already know how to tighten them up correctly. I cant get to all the rods..and hence cannot do them in the proper sequence , and I only need to do the lower drivers side one.
help me,, so I can wrap up this project. I had to remove my leaking radiator and lost some trans fluid ,,,,that is why I had to loosen the rod to check the fluid.
I just installed mine recently, and i don t see why one turn wouldn t still be one turn. Good Luck!
exactly what i thought,, but I was wondering if the sequence had to be done. I guess not, since everyone with an auto will have to loosen one rod and just tighten one rod....
I will do this.
thanks, robin
sorry for the bad spelling and such... I was typing in the dark and did not proof read...( I really need to proof read more often..)
thanks,,,I hope Phil chines in Monday and give me a n easy answer
Strut Rod Pre-Load Adjustment
1. Adjust all four strut rods to a static ZERO-lash first by HAND until they are JUST snub, making sure they are PULLING THEMSELVES TOGETHER during your adjustment procedure.
2. The proper adjustment sequence is as follows: passenger, upper right, driver's upper left, driver's lower left, and passenger lower right.
3. After ZERO lash adjustment is complete, tighten each respective strut rod IN SEQUENCE 1 (one) full turn past ZERO-lash in ∏-turn tightening increments, in sequence until 1 (one) full turn is reached.
DO NOT adjust the pre-load rods tighter than 1 (one) full turn pas ZERO-lash or differential damage/gear whine WILL occur. Once ZERO-lash has been completed for each rod, DO NOT further adjust to ZERO-lash as you proceed through the adjustment sequence even though pre-load rod may "feel" loose before final tightening is completed. These steps are ABSOLUTELY CRITICAL!
4. Lock down each respective pre-load rod jam nut at each Hiem joint stud.
Follow this step for all four main strut rods in prescribed sequence and when you are complete, each respective pre-load strut rod should have tightened up smoothly and evenly.
the one turn after zero is for a new install when you can get to all the bars.
I trust DTE and Phil,, so its 1/2 turn after zero......wheee.....
thanks to Phil, I am back in bixness
