Passenger window 97 coupe
The passenger window stopped working then went down but woukdn't go up, I got it up by lifting it with my hands, now it won't go down but I hear the relay clicking when I push the switch.
Is the motor gone or is there another common problem ?
Thanks in advance for any help.
First things first. The FREE Stuff.
Open the door press and hold the window switch (you pick the direction) Grab the rubber accordion tube between the door and door frame and shake the crap out of it. See if that allows the motor to work. Then slam the door while holding the switch. If that doesnt work, remove the door panel and while holding the switch, bang the motor with a tool. If all that fails, its most likely a bad door control module.
BC
