ARP head stud torque specs
Old Mar 19, 2009 | 09:42 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Default ARP head stud torque specs
The search function seems to be a little off lately, so Im looking for the torque specs for ARP head studs
Old Mar 19, 2009 | 09:51 PM
Corvette-Chris
St. Jude Donor '08
Nevermind, did a Google search and found this:
Are you using arp moly lube?
If so use this:
First pass 25lbft second pass at 50lbft, and finally a 3rd at 70lbft.
Finally install the 5 smaller ARP bolts and torque them to 22lbft.
If using motor oil use this:
First pass 30lbft second pass at 60lbft, and finally a 3rd at 80lbft.
Finally install the 5 smaller ARP bolts and torque them to 28lbft.
(Incase you didn't know you have to lube the threads and washers before installing... you must use either arp lube or motor oil. )
Old Mar 19, 2009 | 10:09 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
vettenuts will probably chime in with better info when he sees this, but I believe ARP upped the values to 80# a year or so ago.
I tq'd mine to 75# (before their revision) and all has been well.
Old Mar 19, 2009 | 10:41 PM
Corvette-Chris
St. Jude Donor '08
Yeah, Honestly I was awaiting either you or him LOL
I just torqued them to 80 and 28 with motor oil
Old Mar 20, 2009 | 01:36 AM
slothy's Avatar
slothy
make sure the beveled part of the washer faces nut!
edit - nm thought u had bolts - arp told me for studs washer orientation doesn't batter, only bolt that it matters
Old Mar 20, 2009 | 10:24 AM
vettenuts's Avatar
vettenuts
Yep, 80 with their lube. Never asked on the motor oil and don't know if that was revised.
To ARP head stud torque specs
