How to manually raise corvette headlights?
Old Mar 23, 2009 | 10:55 PM
superflyrazor's Avatar
superflyrazor
Navigator
Default How to manually raise corvette headlights?
Any help with this would be great!
Old Mar 23, 2009 | 11:09 PM
aleadfoot's Avatar
aleadfoot
Open the hood and turn the ***** at the headlight motor
Old Mar 23, 2009 | 11:13 PM
minitech's Avatar
minitech
And they have a rubber cover over them. Just pull that off and turn to open them.
Old Mar 23, 2009 | 11:30 PM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Dab gum it. That's just something else I'm missing. Rubber covers.
lucky131969's Avatar
lucky131969
Also explained in your owners manual.
Old Mar 24, 2009 | 12:05 AM
LoneStarFRC's Avatar
LoneStarFRC
What's that?
Old Mar 24, 2009 | 12:18 AM
lucky131969
Originally Posted by LoneStarFRC
What's that?
It's a little book in the glove compartment explaining features for your car.......but that's not important right now...
Old Mar 24, 2009 | 11:23 AM
LoneStarFRC
You musta got the deluxe model with a glove compartment.
Old Mar 24, 2009 | 11:50 AM
timemender's Avatar
timemender
Owners Manual (booklet) not to be confused with the Service Manual…..but that’s not important right now………..
Old Mar 25, 2009 | 08:49 AM
superflyrazor
Navigator
Thanks for all the help! I bought this 1999 vette off of ebay and of course there are a bunch of little things going wrong. So far Ive got $2000 in the car with no results from the dealer ship. One of the problems with the car is the head lights will not raise up. Any key things i should look at before i bring it back to the dealer?
Old Mar 25, 2009 | 09:13 AM
chaase's Avatar
chaase
St. Jude Donor '12
Is the headlight motor even turning, i.e. can you hear it moving. Otherwise, check the fuse.
Old Mar 25, 2009 | 11:55 AM
lucky131969
I'm not confused......are you?
Old Mar 26, 2009 | 07:24 PM
superflyrazor
Navigator
I manually flipped my headlights and turned them on and my lights still do not come on. When i push forward to turn my brights on that does not work either if i pull back to turn on my brights they come on. it does not sound like the head light motor is working and does anyone know what # fuse it would be? my fuse cover is worn out. Any ideas?
Thanks Ray.
Old Mar 26, 2009 | 10:30 PM
byronhunter's Avatar
byronhunter
Old Mar 27, 2009 | 12:37 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Theres a VERY COMMON C5 issue that you need to consider. After checking ALL the common things. (fuses and electrical connectors pluged in properly) the steering column MULTIFUNCTION switch is a common issue that can cause this issue.
Theres a comprehensive post in the archive that deatils how to repair this switch for FREE! Do a search and find this post and save a fist load of cash.
BC
BC
Old Mar 27, 2009 | 12:57 AM
olftboy's Avatar
olftboy
Read this....
Originally Posted by Don Lindeman
Check out this link:
http://forums.corvetteforum.com/c5-t...f-replace.html
Notice that one of the pics shows a contact in the switch for the Headlamps UP function. Something has to tell the controller that you want to raise the headlamps. That signal comes from the contacts in the switch.
Before you start tearing into it, try activating the Twilight function using the Configuration Menu on the Driver Information Center (DIC). If the headlamps pop up and turn on automatically when it's dark outside, you've confirmed that the switch is bad because they wouldn't pop up in the Twilight mode up if the controller was bad. If they don't work in the Twilight mode either, then I'd go for the controller.
Don
Taken from here
Old Mar 27, 2009 | 10:44 AM
superflyrazor
Navigator
You guys rock! Ill let you know what i come up with.
Thanks Ray.
To How to manually raise corvette headlights?
Old Mar 27, 2009 | 12:11 PM
hattitude's Avatar
hattitude
Ever been in a Turkish prison?
Old Mar 27, 2009 | 03:05 PM
lucky131969
No, but I do like movies about gladiators........
Old Mar 27, 2009 | 07:48 PM
minitech's Avatar
minitech
Thanks Ray.
So the lights did go DOWN when you powered up and turned off the lights? They moved with power?
Wait a minute... Is this a daytime Corvette? That may explain a few things... And maybe a left handed one???
