Cam Install Question
Old Mar 28, 2009 | 02:22 PM
geezel's Avatar
geezel
Default Cam Install Question
For a 97 LS1:
1. Do you need to pull the cam sensor before removing the cam? If so, does it just pop out of the block after removal of the mounting bolt?
2. I'm installing an LS2 timing set. The cam sprocket has a raised area on the outside face (for the LS2 cam sensor?). This raised area is not an issue for my LS1 application, right?
Old Mar 28, 2009 | 07:23 PM
willyfastz's Avatar
willyfastz
No need to pull the cam sensor and the LS2 gear will work just fine in your LS1.
