Tips on AR header install ?
Old Mar 28, 2009 | 06:02 PM
vettezeke's Avatar
vettezeke
Default Tips on AR header install ?
If you have any tips on installing American Racing headers I would like to hear them. I did a first try and they don't look close to going in. How high does the car need to be, and does the starter need to come loose?
Old Mar 28, 2009 | 06:17 PM
lucky131969's Avatar
lucky131969
It may help if you read the instructions:
http://www.americanracingheaders.com...stallSheet.htm
Old Mar 28, 2009 | 06:19 PM
ZZOOM06's Avatar
ZZOOM06
I installed mine from the bottom. It really helps if you loosen up the starter on the passenger side and take the steering shaft loose on the driver's side. Make sure you remove all the spark plugs and un-do the ground strap from either the frame or engine block on the driver's side.
FWIW these are the easiest headers to install I've ever seen. I had Dynatech Supermaxx LT's on my car before these and they were alot harder to get in. Good luck and keep us posted.
Jimbo
Old Mar 28, 2009 | 06:20 PM
VeroWing's Avatar
VeroWing
Below is a link I found on installing longtube headers on a C5. Different brand, but should provide some basic info. I recently installed Kooks LT headers in my '02, and to be honest, it was a challenge, but not too bad. I had to remove oil filter, alternator, loosen starter, unbolt and jack engine up (one side at a time, with other bolt loose), unhook steering, along with other items. At firtst I thought maybe I had the wrong headers, but after they get where they belong, they fit precisely. I believe I read somewhere that car has to be 28 inches in the air, but I might be mistaken. Hope this helps, Mike.
http://www.ls1howto.com/index.php?article=29
Old Mar 28, 2009 | 07:04 PM
slothy's Avatar
slothy
i used the AR header instructions when i did mine, i didn't have to loosen starter or steering shaft. i did it on jackstands and headers slipped right in. i would get mls header gaskets and not use the graphite ones they give you.
Old Mar 28, 2009 | 08:06 PM
81c3's Avatar
81c3
I just did the TPIS headers and I did remove the alternator and valve covers, and loosened the sterering shaft. I did NOT remove the spark plugs or the ground strap though. I put them in from the top.
When I did the LG's, the drivers side went in from the top and passenger from the bottom.
Old Mar 28, 2009 | 09:33 PM
vettezeke's Avatar
vettezeke
Default AR header install
Yea, I have the install instructions, got the left side in but the right gets caught between the ac line and the block. I took the starter loose but it didn't help. I may have to raise the car more.
Old Mar 28, 2009 | 10:05 PM
vsocks1's Avatar
vsocks1
Didn't loosen starter or steering shaft either....was unnecesary so don't blindly do it unless needed. I did take off coil packs/brackets to make it easier access. Very straightforward install.
Old Mar 28, 2009 | 10:07 PM
Bell's Avatar
Bell
Here you go Vettezeke,
http://forums.corvetteforum.com/c5-t...s-learned.html
Old Mar 29, 2009 | 12:32 AM
KCvetteowner's Avatar
KCvetteowner
Here are some notes I wrote down when I installed mine. I am lucky enough to own a lift so I had the car up high...
Passenger side:
- remove starter (2 bolts)
- move all wiring up and out of the way
- note, AC/compressor bracket was not installed in the car (doing an engine swap so hadn't got to it yet and figured it might help to not have the compressor in the way. An Elite Engineering Catch Can WAS installed on the head.
- Important note, install starter back on the block BEFORE inserting any bolts in the header.
Feed header up from bottom and lead with the part of the flange furthest from you. Push up and twist slightly until flange closest to you is near the bellhousing, tilt far end down a bit and push up.
Drivers side:
- move clutch hose out of bellhousing holder (just push up)
- remove clip on the firewall for the 02 sensor wires (try a test fit and you will see which one is in the way)
- move all other wiring up and out of the way
- note, alternator was not yet installed from engine swap, not sure you would need to remove it.
Feed header up from the bottom and lead with the part of the flange furthest from you. Push up and twist slightly until flange closest to you is near the bellhousing. Far end of the flange should be nearly touching the base of the head, tilt far end down and twist slightly and push up.
Old Mar 29, 2009 | 10:17 AM
vettezeke's Avatar
vettezeke
Default AR header install tips
Thanks for the help, I think I will try losening the ac compressor mount bolts and slide the compressor outward rather than trying to bend the pipe. You would be bending it near where it is welded to the comp manifold. Didn't look like a good option.
Old Mar 29, 2009 | 10:24 AM
Eric Fischer's Avatar
Eric Fischer
Yes, that happened to me too. What I did was dropped the engine cradle by 1/2" and then jack the engine up (place the jack on the bolt of the engine mount) and then the header will slide right in from the bottom. No need to undo the starter or its wires.
Dropping the cradle involves loosening the four nuts. And the motor mounts involve two nuts on the bottom of the cradle.
Old Mar 29, 2009 | 11:59 AM
Patches's Avatar
Patches
No problem installing mine. I did wrap old t-shirts around them while working them in place to minimize the scratches to the ceramic coating. Getting the starter wires reconnected was not easy for me as I could barely fit my hands in there. I left everything loose until it was installed and went from front to back and tightened as I went.
I pre-assembled to make sure all was well.
I also heat-wrapped the starter while I had it out.
Old Mar 29, 2009 | 01:11 PM
SteveDoten@ARH's Avatar
SteveDoten@ARH
Premium Supporting Vendor
Have a second set of hands hold the line away from the header while you slip you don't have to permanently bend it,it in should go no problem no need to move the compressor
Old Mar 29, 2009 | 01:53 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
I installed over 15 sets along w/ Tom and the AR crew at Carlisle last year(dozens more in the past 3 years)
1. It can be done in 1.5 hours w/ 2 skilled wrench turners
2. What size tubes are you using?
3. either way, don't touch the a/c comp
To Tips on AR header install ?
