EBCM replacement / codes / how to reset ?
Old Mar 28, 2009 | 06:16 PM
Konstantin's Avatar
Konstantin
Default EBCM replacement / codes / how to reset ?
98 w. rear mounted EBCM, ABS and TC were on. i got a replacement EBCM, used. replaced the electronic part of the EBCM/Pump assembly and erased the codes, but code 1234 keeps coming back right away, with maybe a 2 second delay after reset. both lights are still on. i did not disconnect battery or anything other than replaced the part.
any ideas ?
thank you.
- Konstantin
Old Mar 29, 2009 | 05:28 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Look in the under hood fuse box and check the ABS 40 amp fuse. If the fuse is good the BPMV motor may be stalled. You can hook a 12 VDC power supply up to pin 8 inside the module and run the pump to fre it up. The other lead will need to go to ground.
Let us know what you find
BC
