Upgraded TPMS
Old Mar 31, 2009 | 02:59 PM
brookman's Avatar
brookman
Default Upgraded TPMS
Piece of cake. 4 new sensors, 2 new key fobs and the receiver.
before removal
Original Receiver
New Receiver with new plug
Inline with old connector
I got the parts from gmpartshouse.com .
25773946 tire pressure indicator sensor, 2001-2004 - $36.32 4 each required.
10312535 remote control door lock receiver, 2001-2004 - $67.01
25695954 un-programmed remote control door lock transmitter, fob 1, 2001-2004 - $41.04
25695955 un-programmed remote control door lock transmitter, fob 2, 2001-2004 - $41.04
12102635 Connector - $26.12
Last edited by brookman; Jul 6, 2009 at 02:56 PM. Reason: edited connector part number.
Old Mar 31, 2009 | 04:04 PM
zagger's Avatar
zagger
Did you have the large pressure sensors before and were able to switch to then newer style (smaller). I'm not sure when they switched 2000 or 2001? Mine are getting old and it's only mater of time before I'll have to replace them, if I could I would switch over to the new style. Thanks for the info and part #'s.
Old Apr 1, 2009 | 01:38 PM
brookman's Avatar
brookman
The 'new' ones are from 2001+
My old ones were the originals.
Old Apr 1, 2009 | 03:25 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Nice job!
I bet it was a sweet sound to hear the horn beep, when you trained the new sensors and key fobs.
Old Apr 1, 2009 | 04:07 PM
C5Y37's Avatar
C5Y37
does the connector come with leads and is it a 4-way? I'm coming up with a 12102635.
Old Apr 2, 2009 | 01:08 AM
brookman's Avatar
brookman
I just verified on the packaging that you are correct about the part number. It is 12102635
It is the 4-way connector with wires and 4 crimps .
After I installed the receiver the first thing I programmed was the remotes and when the first one was recognized I was so excited - then the horn honk from the TPMS.
Old Jul 6, 2009 | 02:00 PM
GEO 8's Avatar
GEO 8
before removal
Original Receiver
12102645 Connector - $26.12
PART NUMBER ISNT COMING UP WITH PARTS HOUSE?
Old Jul 6, 2009 | 02:19 PM
ABNVET.I's Avatar
ABNVET.I
I got mine right from the dealer and there are 4 wires on it. I cut the unused wire off.
Also I found my remotes on that internet site new in the bag GM FOBs 24.00 shipped for both.
Old Jul 6, 2009 | 02:20 PM
GEO 8's Avatar
GEO 8
Was the part # correct??
Old Jul 22, 2009 | 10:55 PM
GEO 8's Avatar
GEO 8
well after 2 hours.................I still cant get the TPS nor the FOBS programed
anyone that can help would be appreciated
all wires hooked up and checked 20 times
HELP ANYONE
Old Jul 22, 2009 | 10:59 PM
GEO 8's Avatar
GEO 8
all 3 wires connected correctly, checked that 4 times
but when you get to the reset til the "ipc learn lLfront tire" is supposed to come up, it never does
Old Jul 22, 2009 | 11:18 PM
Gregory0729's Avatar
Gregory0729
I upgraded my 98 with 02 receiver, tpms and fobs yesterday. Works great and was an easy fix. Thanks!
Old Jul 22, 2009 | 11:55 PM
brookman's Avatar
brookman
Originally Posted by GEO 8
It looks like the 8 pin conn is using the bottom row, and the pins from the receiver go into the top???
look at the picture on the top of this thread
http://forums.corvetteforum.com/c5-t...sensors-2.html
Old Jul 23, 2009 | 06:48 AM
GEO 8's Avatar
GEO 8
Old Jul 23, 2009 | 08:58 AM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Did the new fobs program?
Old Jul 23, 2009 | 09:00 AM
GEO 8's Avatar
GEO 8
nope, they wont program either
item 6 is what wont happen?
1) Turn ignition on
2) Press "Reset" button in order to clear any IPC display warning messages
3) Press and release the "Options" button on the DIC to scroll through the display options until the IPC display is blank
4) Press and hold the DIC "Reset" button for 3 seconds
5) Press the "Options" button again until TIRE TRAINING message appears
6) Press "Reset" button until the IPC "Learn L Front Tire" message appears in order to begin the programming
7) Install the J41760 Tire Pressure Monitor (TPM) System Programming Tool (large magnet will do) over the left front valve stem
8) The horn will sound, indicating the left front TPM sensor is programmed (if this takes more than 15 seconds, pull magnet back and try again, it will give you three tries. Then you must start over)
9) When the horn sounds, proceed to program the next TPM sensor in the following order as directed by the IPC messages: -Learn R Front Tire -Learn R Rear Tire -Learn L Rear Tire Programming can be canceled by turning ignition off, waiting 2 minutes with no sensors being learned, finishing all 4 wheels or through the DIC. If the programming is canceled with less than 4 sensors learned, it will only accept the codes programmed up to that point.
Old Jul 23, 2009 | 09:07 AM
Mark C5's Avatar
Mark C5
Check fuse 27 in the footwell fuse box.
To Upgraded TPMS
Old Jul 23, 2009 | 09:10 AM
GEO 8's Avatar
GEO 8
thought fuse box was in eng compt?
DIC all lights on each step just cant get to item 6
Old Jul 23, 2009 | 09:25 AM
Mark C5's Avatar
Mark C5
It sounds like you are not getting power to the receiver. Power comes from the HVAC circuit and the fuse is located in the fusebox behind a removable panel in the passenger side footwell. If fuse 27 is good, pull your codes and use a voltmeter to see if you are getting power at the connector to the receiver. If you are getting power, I'd say you have a bad receiver.
Old Jul 23, 2009 | 09:29 AM
GEO 8's Avatar
GEO 8
so its possible that the DIC seems to function correctly until item 6 is tried, even if a fuse is bad?
