Front end wobble
Old Apr 5, 2009 | 03:36 AM
AmMscl's Avatar
AmMscl
Default Front end wobble
Hey guys I have a 03 Z06 with 34K on her and I recently noticed that when I'm pulling into a parking spot, cranking the wheel pretty hard, the front end seems to slide or wobble ...maybe even bind. This is at a very slow speed! I tried doing some slow figure 8s the other day and its definitely the front end...and not the surface. Maybe wheel bearings ?????
I'm set to deploy real soon and don't want to worry about the wife and kid having a problem with the Z
Any input would be great, as my search came up empty
Old Apr 5, 2009 | 06:41 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
At steering stops and slow the binding feeling is very normal. It will show up more on smooth surfaces like in a garage with treated concrete floors.
I wish you best of luck on your deployment!
Old Apr 5, 2009 | 12:02 PM
AmMscl's Avatar
AmMscl
Thank you brother!
Old Apr 5, 2009 | 12:47 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
The front end suspension and steering should not wander or wobble even at full lock. Place the car on a rack and inspect the following: lower control arm adjustment bolts (two per lower control arm), these should be very tight; check the steering rack attachment fasteners and steering shaft tie rod ends for looseness or signs of excessive play.
Old Apr 5, 2009 | 12:56 PM
happa's Avatar
happa
Mine does the same thing. Checked the front for weeks, never found anything wrong. Then I found out its normal
Old Apr 5, 2009 | 01:16 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
You are calling this normal?
Old Apr 5, 2009 | 01:45 PM
Bill Dearborn's Avatar
Bill Dearborn
Yes, there is nothing wrong with the car and it doesn't matter whether other cars do it or not. Its a "So What?" situation.
Bill
Old Apr 5, 2009 | 03:18 PM
AmMscl's Avatar
AmMscl
Bill
Care to explain your point of view a little better IRT "So What situation"...
Old Apr 6, 2009 | 06:12 PM
AmMscl's Avatar
AmMscl
Just trolling I assume
To Front end wobble
