Valve Cover Drip Tabs?
Old Apr 5, 2009 | 10:35 PM
geezel's Avatar
geezel
Default Valve Cover Drip Tabs?
I bought a used set of Z06 valve covers to go with my new 243 heads (I had perimeter style). There has been some grinding underneath the covers. Should there be drip tabs on these? If so, is it a problem with stock rockers and no drip tabs?
Old Apr 5, 2009 | 11:09 PM
lucky131969's Avatar
lucky131969
Drips tabs? Are you referring to baffles?
Old Apr 5, 2009 | 11:19 PM
geezel's Avatar
geezel
Maybe I am referring to baffles (my L98 Vette had drip tabs). The valve covers in question are bare underneath.
Old Apr 6, 2009 | 05:36 AM
vettenuts's Avatar
vettenuts
Likely done to clear aftermarket rockers. I had to do the same on mine and most aftermarket valve covers don't have the baffles either. The only issue you "might" have is pulling more oil into the PCV system.
What PCV setup are you running?
I switched to the 04 setup where the PCV is under the valley cover and the only hose required is the fresh air hose on the passenger valve cover.
Do these valve covers have the correct PCV connections for your setup?
Old Apr 6, 2009 | 08:31 AM
geezel's Avatar
geezel
I've done the LS6 PCV conversion so I guess I'm good to go with these valve covers.
To Valve Cover Drip Tabs?
