Testing Diff Clutches
Old Apr 6, 2009 | 05:56 AM
Atok's Avatar
Atok
Default Testing Diff Clutches
Is there anyway to test rear differential clutch packs without disassembling the diff for inspection?
I'm going over my Z06 before I start driving it this season. When I pulled the rear wheels off I noticed my left rear tire was worn much more than my right rear. Then I remembered one burn out I did where I had rubber on the left rear quarter panel but not so much on the right rear. I'm wondering if my diff is not locking properly. No diff noise, 60k miles, fluid looked clean when I drained it.
Anyway to test it?
Old Apr 6, 2009 | 06:04 PM
Atok's Avatar
Atok
bump
Old Apr 6, 2009 | 07:27 PM
vsocks1's Avatar
vsocks1
Well I don't know an official procedure but if I were you I would at least put down a water patch and do a burnout. Verify that both tires are spinning. Short of that I would call RPM Transmissions and get there advice!
Old Apr 6, 2009 | 08:21 PM
AllVette's Avatar
AllVette
Jack up only one rear wheel, car in neutral, all brakes off. Put a torque wrench on the axle nut and measure the force needed to turn the wheel. If the wheel turns easily the limited slip is not working.
I have not seen a spec for the proper torque needed to turn the Getrag diff but I believe it was around 70 ft lb for the old posi's. (If memory serves, it has been a long time since I worked on a 12 bolt posi.)
Old Apr 6, 2009 | 08:27 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Did you drain the fluid before or after the issue? What type of oil did you end up using?
Old Apr 6, 2009 | 08:49 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Thats the procedure that I was told also
BC
Old Apr 6, 2009 | 08:59 PM
vsocks1's Avatar
vsocks1
BC
But a big burnout would be much more fun!!
Old Apr 6, 2009 | 09:07 PM
Eric D's Avatar
Eric D
Unless there really is something wrong with the diff and you ended up with diff parts all over the ground....
Old Apr 6, 2009 | 09:08 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You would NEVER catch me ever doing a burnout:
Now that was FUN!
BC
Old Apr 6, 2009 | 09:17 PM
vsocks1's Avatar
vsocks1
Now that was FUN!
BC
Guess your diff was working fine and passed the test!
Old Apr 6, 2009 | 09:19 PM
vsocks1's Avatar
vsocks1
Really the fastest way to shake it all out!
Old Apr 7, 2009 | 06:06 AM
Atok's Avatar
Atok
I just drained the fluid last weekend. It looked fairly clear. I was going to replace it with the stock GM fluid & friction modifier.
When jacked up, in neutral, and I turn one wheel it turns fairly stiffly but nowhere near 70 ft.lbs. The opposite wheel turns in the same direction which I know is correct for a limited slip diff. Both wheels have the same tension. It would be nice to know what torque is "correct" for the Getrag.
To Testing Diff Clutches
