PLease help with cam
Old Apr 6, 2009 | 01:07 PM
darkstang5887's Avatar
darkstang5887
Default PLease help with cam
I have a 2002 z06 21k miles stock. i will be putting on vararam, obx headers with TI exhaust mod. whats a good cam that had a loapy idle and alot of power. it will see the drag strip a few times a year and is my DD. i may alos supercharge next year thanks for the help
Old Apr 6, 2009 | 02:34 PM
black98c5's Avatar
black98c5
Your best bet is to call a few vendors here on the forum and discuss what your expectations are, and they will point you in the right direction. Picking a cam can drive you . Sice you plan on going with F/I down the road, you have to put that into consideration as well when choosing a cam.
Good luck!
Old Apr 6, 2009 | 02:48 PM
sami85L98's Avatar
sami85L98
If u want choppy idle and great numbers than FTI street sweeper 228/232 with 111 LSA and lift is around 600. Or since u will be adding SC than u might want something like G5X3 with 114 LSA.
Old Apr 6, 2009 | 03:57 PM
squidwards vert's Avatar
squidwards vert
You can go a little bigger cam without piston to valve clearance issues.
232-236 on a 114
Old Apr 6, 2009 | 04:50 PM
LightFighter_GXP's Avatar
LightFighter_GXP
I have a torquer v.3 with some milled LS6 head and they cleared the pistons... but it was too close for comfort so I had valve reliefs cut in them
I got 641 on the intake side and 598 on the exhaust 231/234 111 LSA
Old Apr 6, 2009 | 10:25 PM
darkstang5887
ive heard good things about the g5x3. is that cam superchrager friendly? also would i have to change my ls6 springs for that cam?
Old Apr 6, 2009 | 11:06 PM
slvr76's Avatar
slvr76
You should change the valvesprings with any of the mentioned cams in this thread. Pretty cheap insurance, and the stockers just really aren't up to the job.
Old Apr 6, 2009 | 11:12 PM
happa's Avatar
happa
Id say a G5X3 on 112. Buddy of mine had that cam on a stock LS1 made 410 rwhp and drove really well
Old Apr 7, 2009 | 11:31 AM
black98c5's Avatar
black98c5
The G5X3 is a great cam! I have it in my car and when tuned right, shouldn't be a problem even for a DD.
You will definitely need a dual spring for this cam. Patriot golds or Extremes are a great choice.
Old Apr 7, 2009 | 01:16 PM
STIRitUP's Avatar
STIRitUP
It can be supercharger friendly, all depends on what LSA you go with on it. When I did my research I was told to go 114 or higher if you plan on going S/C. You will lose some lope sound to it as compared to a lower LSA but once you S/C you will not lose boost as it will blow through with a lower LSA
Old Apr 7, 2009 | 09:17 PM
ROJO99's Avatar
ROJO99
On my second cam and currently running the Whipalsh from Gulf Coast performance (England Green) and very happy. with stock heads and injectors (for now) I recorded 402/374 on a DynoDynamics dyno. As stated above call a few vendors and talk about your set-up and goals for suggestions.
Old Apr 9, 2009 | 11:55 PM
darkstang5887
The only problem is that the shops always recomend thier cams of course. Also the flow tech street sweeper and Texas speed look promising. There's too many tochoose from. I would like around 500rwhp with capabilities of Being a DD and with a somewhat loapy idle
Old Apr 9, 2009 | 11:57 PM
darkstang5887
I'm think the g5x3 maybe be too much for a DD after lookin on YouTube
Old Apr 10, 2009 | 12:02 AM
vsocks1's Avatar
vsocks1
Sorry, you will not get anywhere near 500 rwhp with headers, cam, and Ti mod. Time to seriously rethink your plans or goals!
Old Apr 10, 2009 | 10:25 AM
darkstang5887
my plan in the end is to have stage 4x ls6 heads, cam, headers,ti, fast 90/90, injectors,vararam, and some other goodies, i think 500 could be possible
Old Apr 10, 2009 | 10:51 AM
black98c5's Avatar
black98c5
If 500rwhp is your goal, then I would look into skipping the H/C for now, and go straight to a blower. by the time you do H/C/FAST 92 etc..you could have bought a blower, and make a lot more power with stock-like driveability.
Old Apr 10, 2009 | 10:54 AM
jedblanks's Avatar
jedblanks
And most of the SOTP power is in the tune, not in the peak HP number on the dyno curve. I've seen many 430 HP street tuned machines that sound and feel WAY more powerful than a 500 hp dyno queen.
And you can't go wrong with whatever EnglandGreen puts in.
The Whiplash II is amazing.
To PLease help with cam
Old Apr 10, 2009 | 11:29 AM
AU N EGL's Avatar
AU N EGL
This sounds good. But you will also need to change your springs. Z06 springs are not good above a 5.75 lift. Plus new push rods. the stock ZO6 cam is a smaller diameter IIC to the rods are longer.
I run a 224/224 581/581 on 112 with 918 springs.
Small cams may not be a popular item, but the throttle response is far better then many big cams. and quicker off the line or out of corners
SC need small cams. Stick with the stock Z06 cam if your adding a SC.
Old Apr 10, 2009 | 12:58 PM
squidwards vert
Old Apr 10, 2009 | 02:01 PM
sami85L98's Avatar
sami85L98
I recommend G5x3 on 114 LSA for a SC, as he wants choppy idle too, seems like op wants best of both world power of FI, and sound of a N/A.
