Noise from 2000 6 sp.
Old Apr 10, 2009 | 12:21 PM
"Uncle T"'s Avatar
"Uncle T"
Cruising
Default Noise from 2000 6 sp.
Any Ideas? Marbles sound coming from trans or rear, only when coming out of 1st gear. Gets worse after warm up. Runs strong, no other weird sounds or anything loose underneath. Thanks!
Old Apr 10, 2009 | 01:39 PM
BELVIN20's Avatar
BELVIN20
Normal noise, they all sound like that, my 2000 Vert sounds just like that and has sounded like the marbles are loose since day one, and I have 43k on it now, just the way the MN6 sounds. Keep on driving.
Old Apr 10, 2009 | 01:58 PM
GreenDream's Avatar
GreenDream
Yep... marbles.. that describes my 2000 Vert 6 spd exactly. And it magnifies if you hang on the stick between shifts.
Old Apr 10, 2009 | 02:34 PM
FASST LN's Avatar
FASST LN
If you keep the rpm over 1,500, then it is less likely to happen...for me anyway.
Old Apr 10, 2009 | 03:51 PM
"Uncle T"'s Avatar
"Uncle T"
Cruising
Thanks for the reply. This just started last week. Has it always been there for you and has it happened after 40,000 or so miles?
To Noise from 2000 6 sp.
