Head damage-Can it be repaired
Old Apr 11, 2009 | 03:20 PM
nickolbag's Avatar
nickolbag
Default Head damage-Can it be repaired
I got these off the forum a year ago with the intentions of porting them. Plans changed and I now decided I would sell them. When I got them I pulled them out of the box one time to verify they were 243s and didn't really give them much more attention. Well I unpacked them today to clean them up and get some pics to sell and noticed a dent in the corner of one head. Not sure if it happened during shipping(box wasn't damaged) or if they were sold that way. I got them from a member that posts regularly so if they did ship that way I am sure he was not aware of it. Either way it's been a year and my fault I did not check them when I got them so I am not going to bother him about it. I'll just sell them dirt cheap or scrap them.
This is the damage............
My questions is....can this be repaired? Can the deck be shaved? If the heads are going to be milled anyways will that take care of it?
Old Apr 11, 2009 | 03:21 PM
slothy's Avatar
slothy
no pic
Old Apr 11, 2009 | 03:27 PM
nickolbag's Avatar
nickolbag
I see 4 pics.
Old Apr 11, 2009 | 03:29 PM
slothy's Avatar
slothy
they show up now
i would think with them getting decked and you can prob have the intake side filed down flat enough since it isn't a seal surface there.
Old Apr 11, 2009 | 04:58 PM
TheCartel's Avatar
TheCartel
That's nothin to worry about man.
Old Apr 11, 2009 | 05:34 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Just make sure that area is flat and you should be good to go.
BC
Old Apr 11, 2009 | 05:44 PM
vettenuts's Avatar
vettenuts
Not a critical area but it must be flat with the rest of the head to keep from holding the rest of the head up and not sealing.
Old Apr 11, 2009 | 06:22 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Nick, They're junk...
I'll give you $20 for them...
Maybe I'll make a coffee table out of them.
Old Apr 11, 2009 | 08:53 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Counter offer
I'll give you more money This is the best deal that your going to get. I'LL GIVE YOU $59.99 for then and I will pay half of the shipping ! Thats the best I can do.
BC
Old Apr 11, 2009 | 10:42 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
$62
Old Apr 11, 2009 | 11:34 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I have BIDNAPPER,,,,,,your a GONER! $63.
BC
Old Apr 12, 2009 | 12:35 AM
DuronClocker's Avatar
DuronClocker
Sell them cheap, I'll pick them up
Really, that shouldn't be an issue at all... not a sealing issue at all if you were to have them milled... or even took a grinder to that corner.
Old Apr 12, 2009 | 12:55 AM
chevy406's Avatar
chevy406
I agree with the other posts above - use a flat file to knock down the high point on the sealing surfaces, and then put those heads to work. As long as the water jacket isn't leaking, you will be good to go. The critical areas are the combustion chambers and the ring around to bore diameter.
Old Apr 12, 2009 | 09:29 PM
nickolbag's Avatar
nickolbag
Ok so it seems I can file these down myself. What exactly should I use to file it down?
Or would it be best to just sell them at a discount and not tackle this myself?
Old Apr 12, 2009 | 09:39 PM
vsocks1's Avatar
vsocks1
I would just take it to a good machine shop and let them take care of it. Shouldn't be too much and then you know it is right.
Old Apr 12, 2009 | 09:48 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Just use a fine single cut flat file. Hold the file FLAT against the head and run the file LIGHTLY across the the area in a DIAGONAL direction. If there are any high spots,,,you will see the file take metal off that spot. Once that spot is flush, the file will start taking metal off the rest of the head. Thats when it's time to stop.. Then wrap some 600 grit wet & dry paper once around the file and lightly go over the area.
Thats all there is to it. The entire process should take 5-10 minutes max on one head.
While you have the head off, get a 24" machinest rule and lay it on EDGE across the head. Use a 0.002" - 0.003" feeler gage and attempt to run it under the rule. If the head is flat, it shouldnt slide under. Check it in an X pattern and straight across.
If it does, you may want to have the head surface lightly milled
BC
Old Jul 14, 2010 | 04:25 AM
stryderss's Avatar
stryderss
hmm i wish the pics of the head damage were not deleted, this thread might be some help to me!!!
To Head damage-Can it be repaired
