Need Help
Old Apr 14, 2009 | 07:27 PM
glass73's Avatar
glass73
Default Need Help
Can anyone direct me to the best belt tensioner? My belt keeps jumping up on the alternator. Have a 98 Lingenfelter. I tried the search link but nothing comes up. Thanks in advance for any help.
Old Apr 14, 2009 | 08:45 PM
lucky131969's Avatar
lucky131969
I assume you have checked for misalignment or a balancer issue....if either are the case...adding more tension won't help.
Old Apr 14, 2009 | 10:05 PM
glass73's Avatar
glass73
The tensioner must be tired because the belt feels loose
Old Apr 14, 2009 | 10:07 PM
glass73's Avatar
glass73
I didnt address a balancer issue. Could some fill me in on that? Thanks for any input!
Old Apr 14, 2009 | 10:13 PM
lucky131969
Ok, it helps to know that up front....
Old Apr 14, 2009 | 10:18 PM
glass73's Avatar
glass73
Sorry, I get ahead of myself. But now that we know that, what the **** should i do. I do most of my own work (keeping it out of the shop is a plus as far as Iam concerned). I did use a metal machinists rule to line up the pulleys and they all looked pretty good.
Old Apr 14, 2009 | 10:21 PM
lucky131969
Ok, does the maggie setup still use factory tensioner setup? Just identify which one is limp, and order it. If it does, you can get it at gmpartshouse.com, but the factory tensioners are pretty easy to come by at local parts houses.
Old Apr 14, 2009 | 10:25 PM
glass73's Avatar
glass73
Do you think there is any advantage in one of the manuel tensioners?
Old Apr 14, 2009 | 10:38 PM
lucky131969
Sure, I know a guy that has one on his maggie setup. It's an ECS tensioner.
To Need Help
