need help with headers
Old Apr 18, 2009 | 12:09 PM
sickc5vette's Avatar
sickc5vette
Default need help with headers
guys i had a local shop put my kooks long tubes 1 7/8 headers on my c5 and and now i want to take them off to go back to stock and im having a hard time i was able to take off the headers .but they wont come out can you guys help me i have them sold and need them off the car .i heard something about the cross member
Old Apr 18, 2009 | 12:46 PM
Fratbragen's Avatar
Fratbragen
not sure about Kooks specifically, but LS1howto.com does a great write up on LG Lt installation. With my lg streets the Pass side went in / or out from the top. The driver's side from the bottom. Good luck.
Old Apr 18, 2009 | 01:28 PM
ZZOOM06's Avatar
ZZOOM06
If they are the earlier Kooks you need to jack up the motor a bit to get them off.
Old Apr 18, 2009 | 02:42 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Old Apr 18, 2009 | 03:10 PM
sickc5vette
i do have the motor up and what you mean by jack up the motor you mean have it on two ramps ? . both headers are loose but theres a piece in the middle that wont let me take them out
Old Apr 18, 2009 | 03:25 PM
dmiz0420's Avatar
dmiz0420
a H pipe?
a X pipe?
Old Apr 18, 2009 | 03:32 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
You have to take the engine mounts loose and place a jack with a board between the jack and the engine and raise it off the engine cradle a few inches to allow enough clearance for the headers to slide clear. Normally the left side (drivers side) can be pulled down below the vehicle and the right side up and out the top.
Be careful!!
Old Apr 18, 2009 | 04:02 PM
Fratbragen's Avatar
Fratbragen
Be careful!!
Yeah Sick, I second the Be Careful part. It sounds like you need to study up on procedure before you go further. The Headers install done in your garage takes some planning and strategy to get done. Not saying it's overly difficult, just need to understand what needs to be removed and what can stay. If Passenger side header is coming out going up, then you need to disconect the AIR tube, remove the coil packs, removed the valve cover, and most likey belt tensioner and then you can remove it nice and slow.
If the Driver's side goes out the bottom, then the car needs to be at least 22 or so inches high (if not higher) in the air. This is pretty high and safety can be a concern if you are not careful. Sounds like from Kooks guys thus far the motor has to be jacked up just a tad to get some clearance.
Old Apr 18, 2009 | 04:23 PM
sickc5vette
guys i will do it the way you guys tell me .whats the fastest way .i have the car on two ramps so the front of the car is super high .is that what you mean by the motor being jacked ..ur right i have no ideal what needs to be left and what needs to be taken out .both headers are completely loose .there dangling .and its an x pipe .all ur words would be greatly apreciated
Old Apr 18, 2009 | 04:25 PM
sickc5vette
what do you mean by this( engine mounts loose and place a jack with a board between the jack and the engine and raise it off the engine cradle ) i took off the spark plugs and the valve covers are both off .
Old Apr 18, 2009 | 04:54 PM
Fratbragen's Avatar
Fratbragen
Have you read the header install on LS1howto.com yet? Seriously, check that out and it will help you see what you need to do. Oh, and you'll need a hydraulic jack to raise the car up high enough off the ramps to run the header out the bottom.
Old Apr 18, 2009 | 05:25 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I had the Kooks first generation headers in bro's car. Whoever installed them did a hack job and then welded all of the pipes together including the mid-pipes, what a bunch of azzhats.
Took forever with a cut-off tool and saw to get them out.
In general you should disconnect the battery, steering, ground cables, FRC covers, coil packs, spark plugs & wires and starter. In some cases the valve covers.
With the kooks you might have to remove oil filter too along with water temp connection and oil level connector.
We also remover the 18mm nuts on the front cross member and used a 2 x 4 to roll the engine from one side to the other.
Old Apr 18, 2009 | 05:53 PM
sickc5vette
wow thats scary .ive never done that before .tom i will look at ir very good and see what needs to be done cause i refuse to pay someone to do it for me lol .how things are now im better off trying to do it myself .
Old Apr 19, 2009 | 12:52 PM
sickc5vette
guys im new to taking some of these parts apart .i really need to know where the steeering shaft is .and what parts need to be taken out and left
Old Apr 19, 2009 | 12:54 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Steering shaft is on drivers side. 13 mm bolt. lock the steering wheel and mark the shafts. Make sure you don't spin anything. Look below the alternator.
Old Apr 19, 2009 | 01:42 PM
sickc5vette
i hate this .now i have to mark the shaft my god .this is hard lol
sickc5vette
do i have to take that off to take the headers off or to install them
To need help with headers
Old Apr 19, 2009 | 01:57 PM
lucky131969's Avatar
lucky131969
This has bad stuff written all over it. Based on the questions you are asking, I suggest you get some help. Perhaps a local forum member with some experience can assist you.
Old Apr 19, 2009 | 03:12 PM
sickc5vette
that would be great i live in miami fl .and some help would be great .i took pics of what is giving me a hard time.the headers are off .but theres a peice i think its the cross memeber .it has a bolt and i feel if i take it off it will give me clearance to be able to take the header off
sickc5vette
just dont know how to post up the pics
