Cam specs for daily driver
Old Apr 18, 2009 | 01:10 PM
Fratbragen's Avatar
Fratbragen
Default Cam specs for daily driver
Please post your cam size and your opinion of driveability. I'm looking for a nice cam that can be driven daily with great reliability etc. Thanks much,
Matt
Old Apr 18, 2009 | 01:33 PM
TurboBerserker's Avatar
TurboBerserker
A4 or M6? Stock otherwise?
Old Apr 18, 2009 | 02:10 PM
Fratbragen's Avatar
Fratbragen
M6 - Blackwing CAI, Ported Tbody, LG Street LT's, high flow cats, Meziere electric water pump, Z06 TI's exhaust, Dyno tune. Making 358 HP, 366 TQ.
Old Apr 18, 2009 | 02:46 PM
TurboBerserker
Since you are in CA, I assume you want it to smog.
A very streetable (e.g. small bump over stock) would be something like a 210-212/216-218, mid 500s lift, and a 114-115 lsa. This would benefit from tuning, and would likely have a very (and I mean very) mild lope if any. power range would be 1500ish- 6000ish
If you want to be a bit more aggressive, you could do something like a 216/220 and mid 500s lift, on a 114 lsa. It would be a bit coppy at idle and the power range would be in the 2000ish to 6200ish range You want a retune with this cam.
More: 222/228 550s lift 114lsa: choppy, power range: 2000ish to 6500ish. You want a retune with this cam. (this is probably starting to scrape the "too big" range with stock heads)
Really aggressive: 224/232, high 500s, 114 lsa: choppy, power range: 2250ish, 6500ish. You want a retune with this cam. You also want heads and springs
Max power is your goal: 234/244, low 600s, 114 lsa: rough idle, power range: 3000ish 6700ish. Retune, heads and springs.
Hard to say what drivable means to you -- a lot will depend on how good the tune is that goes with the cam... General rule of the thumb, the bigger the cam, the harder it will be to get the tune right (which translates to less drivability if you are not doing the tune yourself or a dyno tune).
Old Apr 18, 2009 | 03:47 PM
Fratbragen's Avatar
Fratbragen
Turbo, thanks for the great info. I would intend to put on heads eventually, so I'd like to install a cam that would complement that future mod. Not sure about the smog thing, I'd assume a good tune would help get the car where it needs to be to pass, but that's hard to say.
Old Apr 18, 2009 | 04:17 PM
AJay's Avatar
AJay
I'm running a 214/220/ 118 LSA Comp cam with AFR heads and putting 412 RWHP to the ground with a car that drives like stock. No rough idle and no shake and 31 MPG on a trip.
I couldn't be happier
See my profile for all mods
Old Apr 18, 2009 | 04:23 PM
TurboBerserker
Happy to help.
Going really wide on the LSA will help eliminate rough idle at the expense of top end power. It is a really nice way, however to run more cam than you'd otherwise put up with.
Frat -- you could run the bigger cam now, just upgrade your springs when you do the swap. The reason some of those cams would want heads is simply because their lift will be much higher than the head will support efficiently. Generally speaking, you want to hit your max flow point on the heads 2x -- once as you got the max lift of the cam and once right after -- so that you are getting the most flow possible.
With stock heads, you will be pushing them past their sweet spots for flow by a quite a bit for the big cams I mentioned above. Your other alternative would be to reduce the lift on those cams, and when you buy your heads, just get a set that match the lift of the cam.
Old Apr 18, 2009 | 04:49 PM
Fratbragen's Avatar
Fratbragen
Turbo, a friend is recommending to start going with upgraded springs and a COMP 232-236 (I'd also throw in upgraded rods). He said this is as big as I can go and still be streetable. Then, I can upgrade the heads down the road. Your thought sir?
Old Apr 18, 2009 | 05:39 PM
TurboBerserker
That's a pretty big cam. It will require a lot of tuning to make it behave nicely while idling correctly.
Having said that, I ran a 236/230 in my daily driver for years, although it was a 408 and the cubes ate up some of the cam. I will also be running a 234/244 in my current daily driver (which is also a 408), but I'm also comfortable doing my own tuning and will not stop until I have the idle tuned in correctly.
Personally, until you have the heads, etc., I think that cam is too big and may hurt your performance rather than helping.
What are the rest of the specs on that? (lift, lsa).
Old Apr 18, 2009 | 05:45 PM
sami85L98's Avatar
sami85L98
Lg G5x1-E.
Old Apr 18, 2009 | 06:15 PM
Fratbragen's Avatar
Fratbragen
Not sure on lift, but it's a 114 LSA. If that's too big, what's the next step down, but would benefit from a future head swap? Again, thanks for your opinions. What's your background in this, you seem to have a a lot of experience. Thanks, Matt
Old Apr 18, 2009 | 07:08 PM
MarkT 2002's Avatar
MarkT 2002
A cam that size is going to have problems passing the sniffer test in CA. Comp says anything bigger than 220 on the intake and less than 114 LSA is going to have trouble with smog testing in CA. I went with Andy's (A&A) mild blower cam 220/224 .581/.581 114LSA and put down 408rwhp/388rwtq before I put a blower on. The car has a little lope but has stock manners along with low-end torque. After I put Andy's V-1 kit on I put down 588rwhp/508rwtq with the same cam.
With high flow cats and the above cam I barely passed the sniffer test. In order to pass I really had to heat up the cats and have my tuner sitting in the front seat while it was being sniffed. By the same token I remember reading about some guy passing the CA sniffer test with a G5X-3 (which is a huge cam, and isn't easily repeatable) but I don't remember all the details. Metal-matrix/high-flow cats make it more difficult to pass the sniffer.
Old Apr 18, 2009 | 11:12 PM
TurboBerserker
Anything mid 220s to upper 220s -- like a 224/228 or similar on a 114.
I've been hotrodding for a long time (since the late 80s) and am the Internal Engine moderator on a high performance truck oriented site.
Old Apr 19, 2009 | 12:25 AM
Fratbragen's Avatar
Fratbragen
Great info, thanks much. The G5X-3 is one of LG's cam's right? Any idea of the specs on that bad boy?
Fratbragen's Avatar
Fratbragen
Great, thanks for the knowledge.
Old Apr 19, 2009 | 01:46 AM
TurboBerserker
It's the cam I'll be putting in mine. 234/244 (ish) .600ish lift, 114 lsa
It's in the C5 I'm buying which smogged in San Diego.
Old Apr 19, 2009 | 01:49 AM
Fratbragen's Avatar
Fratbragen
So it passed the sniffer with that cam in it?
To Cam specs for daily driver
Old Apr 19, 2009 | 09:33 AM
TurboBerserker
From what I understand, yes.
Old Apr 19, 2009 | 10:04 AM
AU N EGL's Avatar
AU N EGL
I think the only heads that are CARB approved are AFR205s and the 224/228 581/588 112 that AFR recommends with tune will pass CARB emissions
Old Apr 19, 2009 | 11:27 AM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
Matt
To meet the above criteria and pass smog sniffer we have our ZZ-005 cam. Basic specs are ~ 224°/228° duration and ~.590 Lift - LSA is 114° with 1° advance ground in.
We stock them and they are price at $395
