Broken master?
Old Apr 19, 2009 | 09:48 AM
Nver2loud's Avatar
Nver2loud
Default Broken master?
Hey all, Well, i thought my tranny woes were done after my tranny rebuild over the winter. All was fine and dandy, clutch was still good when i had driveline out (clutchmasters dual friction) and installed a new GM slave. Well, the wife took the car to work on friday, comes home and says its grinding reverse real bad, so im like wtf. I go out and it grinds for me right away once but then didnt do it again after that. I thought it was odd but the pedal felt fine and everything. We take it out to eat, i have too many drinks, so she drives it home. About a block from our house i heard what seemed like a bang coming from the floor area, she didnt know what happened but didnt seem to notice a change in pedal feel. Yesterday morning i go out and the pedal feels like its barely doing anything and its real hard to get into gears. If i pump really fast about 20 times, then it seems to build pressure like it used to.
Does this sound like a blown up master? Time for upgrade or just another stock master?
I do have a speed bleeder and i did try to bleed it agian and flushed the fluid all through with no luck.
Old Apr 19, 2009 | 10:54 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
sounds like the master cyl is internallly bypassing.
Old Apr 19, 2009 | 01:20 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
It sounds like air in the system. Check out this link on what to do...
Bleeding Clutch System
Old Apr 19, 2009 | 07:47 PM
Nver2loud's Avatar
Nver2loud
I forgot to mention that I did look under the dash and it appears some fluid is leaking too.... so im really guessing its a bad master.
Is it really worth it that much to get a tick adjustable master vs a stock ls6 master?
Old Apr 20, 2009 | 10:20 AM
Nver2loud's Avatar
Nver2loud
anybody?
Old May 1, 2009 | 04:58 PM
Nver2loud's Avatar
Nver2loud
To anybody that was following this, it was a bad master. The rod was bent, also leaking fluid into the interior. My clutch bracket that the master twists into was also cracked in half and the master was pushing 1/2 way through the firewall. So anybody who has bled the system and kept having problems, might want to look into the bracket being broke and also the master being bad!
Old May 1, 2009 | 06:52 PM
Eric D's Avatar
Eric D
Did you end up replacing or repairing the bracket? Any photos of the failed parts? Glad to hear you got things back in order.
Old May 3, 2009 | 08:49 AM
Nver2loud's Avatar
Nver2loud
Im a bad poster! I forgot to take photos of the bracket, I was in a hurry when i was fixing it as I did not have much time. I yanked the bracket out took it down to the shop and welded it up quick. It seems to be a REALLY cheap piece...Im surprised its not a bit thicker!! I was also fairly thankful that it was steel and not aluminum, because i would have been up $hit creek...
Old May 3, 2009 | 09:04 AM
Eric D's Avatar
Eric D
Your a great poster! I'm sure your post will help others look at some other factors that might be screwing their clutch system up.
It would be nice to get a photo of a bracket and have you point out the area that cracked. I'll see if I can find one, unless someone else has one.
Thanks!
To Broken master?
