Oil Filter
Old Apr 21, 2009 | 03:26 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Originally Posted by silversport
Old Apr 21, 2009 | 11:32 PM
Magred6sp's Avatar
Magred6sp
Thanks guys,
I think I'll stop by Advanced and pick up a Purolator. I need to go to Advanced to pick up some washers for the Anti-Venom mod anyway. I'll let you know...................................D ave
Old Apr 21, 2009 | 11:36 PM
GODSPEED1's Avatar
GODSPEED1
purolator..is that a joke? I run an automotive shop..there are 2 filters that are acceptable..AMSOIL EA Filters,,and WIX/NAPA GOLD filters... AMSOIL has synthetic nanofiber media,,WIX and NAPA gold (same filters) have glass enhanced cellulose media, each filters 10-12 micron, plus has anti drain back valve, steel coil spring instead of cheap aluminum plate that bends..and a neoprene gasket....
Old Apr 22, 2009 | 12:38 AM
fnsblum's Avatar
fnsblum
The only way you are going to know if your favorite oil and filter are doing a good job is to have an oil analysis done. This is especially true for air filters. Some of you might be surprised. Just removing the rocker covers to do a valve adjustment will show more silicon in your oil. Later! Frank
Old Apr 22, 2009 | 07:37 AM
silversport's Avatar
silversport
Originally Posted by Quicksilver Vert 01
Bill
Old Apr 22, 2009 | 09:33 AM
Rickyh93's Avatar
Rickyh93
I run the Amsoil Ea032 now. I use to run the real WIX filter (not Napa Gold). According to an engineer I met from Wix - Wix makes the Napa Gold filters but the Wix filter is better than the Napa Gold.
Old Apr 22, 2009 | 09:45 AM
GODSPEED1's Avatar
GODSPEED1
ive cut them apart..they are the same, 100%.
