Oil Filter
Old Apr 19, 2009 | 10:29 PM
Magred6sp's Avatar
Magred6sp
Default Oil Filter
What oil filters are you guys using? I will be using Mobil 1 5w 30. I tried the search feature, but its messed up Gives me everything but what I am looking for. I got a filter from the dealership AC DELCO PF46, but I notice Gene at GM Partshouse is selling a Ultraguard PF44 I think? Should I get the different part number? What do you guys recommend? Thanks in advance.............. Dave
Old Apr 19, 2009 | 10:34 PM
ZeeOSix's Avatar
ZeeOSix
The Ultragaurd is a better filter for sure. Any top tier filter can be used. WIX/NAPA Gold, Mobil 1, Amsoil, etc. Many, many to choose from and all will perform well.
Old Apr 19, 2009 | 11:23 PM
Dave68's Avatar
Dave68
I've been using the K&N filter for years. It filters and flows exceptualy well.
Old Apr 19, 2009 | 11:34 PM
ljthe2nd's Avatar
ljthe2nd
I've also been using the K&N oil filter for years and think its a great filter, but a lot of the forum members here have a heart attack about the nut that's welded on the bottom of the filter that makes it so easy to remove.
Old Apr 20, 2009 | 12:18 AM
2KFRC5's Avatar
2KFRC5
I've only 2 PF44's left. If you decide to change and get rid of the 46, I'll take. It's a good filter.
Old Apr 20, 2009 | 09:47 AM
jovette's Avatar
jovette
NAPA Gold
Old Apr 20, 2009 | 10:10 AM
jrose7004's Avatar
jrose7004
I use the K&N Oil Filter.
Old Apr 20, 2009 | 11:35 AM
EStreeter's Avatar
EStreeter
I did a fairly extensive search last week online (not the forum) for "best oil filter" and "oil filter reviews." Hit on a couple of sites that were very interesting and informative. The Purolator PureOne was rated the best with the Mobil 1 as a close second. Actually they were about equal except the Mobil 1 costs twice as much. They both have synthetic media, silcone gaskets and back flow seals and more reliable bypass valving. Each will stop bwteen 95-99% of particles to 10 or 15 microns and have great capacity (hold more crud before clogging).
I just put a PureOne on the car this weekend. $6.00 at Advance Auto.
The ACDelco is made by Champion and was not rated particularly high. The K&N, Napa Gold and Wix were considered good filters but did not have 100% synthetic media or the other features of the PureOne or the Mobil 1. Bosch filters (Champion products) were also thought to be pretty good.
Do search and read the reviews. More information than I ever new about oil filters.
Old Apr 20, 2009 | 06:15 PM
olefam's Avatar
olefam
I use Wix or Napa Gold interchangeably. I'd use the K&N except for the high cost & I forget to buy them at the time I'm getting my oil.
Glen
Old Apr 20, 2009 | 06:26 PM
TEXHAWK0's Avatar
TEXHAWK0
I had trouble with ACDelco filters leaking during a time that I think they might have been making the endplates thinner, so they would not maintain pressure on the gasket.
I switched to WIX, and never had a problem, and I use WIX on all my cars now.
I also now think that WIX is a better filter.
Keep in mind that if you go to an ultra filter, you will also be getting more pressure drop.
I would stay with the standard filter.
Old Apr 20, 2009 | 07:31 PM
ls1impulse's Avatar
ls1impulse
NAPA Gold/WIX
Old Apr 21, 2009 | 12:21 AM
ZeeOSix's Avatar
ZeeOSix
Originally Posted by TEXHAWK0
Keep in mind that if you go to an ultra filter, you will also be getting more pressure drop. I would stay with the standard filter.
I ran the UPF-44 Ultragaurd on my Zee a few times and never say any oil pressure difference. Had also ran the PF-44, Amsoil and WIX/NAPA Gold ... all gave the same oil pressure readings under the same conditions.
Keep in mind that you can only see the added pressure drop due to a more restrictive oil filter when the oil pump is in pressure relief mode (ie, cold start with some RPM). When the pump is not in pressure relief mode (ie, oil is hot and thin), all of the pump's positive displacement volume is going through the filter/engine circuit anyway, regardless of the filter's pressure drop.
Old Apr 21, 2009 | 05:06 AM
NC99's Avatar
NC99
Napa Gold/Wix.
Old Apr 21, 2009 | 08:52 AM
Oldvetter's Avatar
Oldvetter
This is true, and I saw a 10-15 psi increase in pressure during cold startup when I went from a UPF44 to a WIX (or NAPA Gold, same filter).
Old Apr 21, 2009 | 08:58 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Always AC Delco PF-44 filters since new.
Old Apr 21, 2009 | 10:48 AM
itzza427's Avatar
itzza427
Wix here (They also make the NAPA gold)!!
Old Apr 21, 2009 | 11:15 AM
wcsinx's Avatar
wcsinx
This is why I use the Purolator PureOne filters.
To Oil Filter
Old Apr 21, 2009 | 11:44 AM
Quicksilver Vert 01
Can you post any links these sites?
Old Apr 21, 2009 | 02:10 PM
silversport's Avatar
silversport
www.bobistheoilguy.com
Bill
Old Apr 21, 2009 | 02:25 PM
98vettedave's Avatar
98vettedave
Amsoil Ea032 is simply the best oil filter money can buy.
