Corsa Indy or Tourning
Old Feb 4, 2002 | 04:19 PM
HOCKEY's Avatar
HOCKEY
Default Re: Corsa Indy or Tourning (HOCKEY)
Thanks for the help to all and will get to listen to a few before buying.
Old Feb 6, 2002 | 12:47 AM
flipm's Avatar
flipm
Here's a question for everyone in this thread from Maryland/DC/Virginia... where did you go for the install of your exhaust? I saw one posting say "Tony's Corvette" but beyond that.. who do you recommend?
Old Feb 6, 2002 | 02:41 AM
Jim M's Avatar
Jim M
St. Jude Donor '08
Default Re: Corsa Indy or Tourning (flipm)
I installed my Corsa system, so I can't make any recommendations based on experience. However, I've also heard good things about Tony's Corvette Shop and Sport Chevrolet, but I would expect a dealer to charge more for the installation. Any competent muffler shop should be able to do it in an hour or less. Make sure whoever does the install lifts your car properly. Good luck!
Old Feb 6, 2002 | 08:50 AM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
U can install the corsas yourself...
Old Feb 6, 2002 | 08:56 AM
jimk's Avatar
jimk
For those of you who installed them yourself...where you able to do this with ramps and jackstands? I was wondering if you can get the back of the car high enough to get the 1 piece stock muffler/pipe over the rear axle?
Old Feb 10, 2002 | 09:47 PM
HOCKEY's Avatar
HOCKEY
Default Re: Corsa Indy or Tourning (jimk)
Where is Tony's Corvette? And would should I expect to pay to get the Indy's and X pipe installed as I do not have tools and all that to install.
Old Feb 11, 2002 | 02:21 AM
Jim M's Avatar
Jim M
St. Jude Donor '08
You'll need a good floor jack to get the rear of the car high enough to get the stock exhaust off in one piece (each side). I started by backing the car up on a set of Rhino ramps, so I could loosen all the necessary bolts before jacking it up. You have to disconnect the rear anti-sway bar and rotate it down to get it out of the way. You really have to get the rear of the car high, so you can maneuver the stock exhaust down to get it over the axles and off the car. It ain't fun but it can be done. The easy part is installing the Corsa system since the over the axle pipes are seperate from the mufflers.
If you try it, make sure you use axle stands, and be careful. You won't believe how high you have to get the rear of the car. Good luck!
Old Feb 11, 2002 | 03:30 AM
MDL-01C5's Avatar
MDL-01C5
Default Re: Corsa Indy or Tourning (vettenuts)
If you're not going to do A head/cam job, choose the Indy's HANDS-DOWN!!!
Unless you want to pay $800 for a practically stock-sounding system, you'd be a fool to count on the Tourings to do anything noticeable on a basically stock LS1.
The Indy's are LITERALLY invisible at cruising speeds (low RPM)[No BS--quiet as stock!!], but sounds like a sexy American V-8 should at wide open throttle (@ higher RPM)!!!
Don't waste your money on the Touring if you want an aftermarket sound--you'll regret it if you do, especially the first time you hear a set of Indy's blow by you;):D
Old Feb 11, 2002 | 01:34 PM
C5North's Avatar
C5North
From: HOPE is the first step on the road to disappointment.
INDY'S :smash:
Old Feb 12, 2002 | 11:32 PM
HOCKEY's Avatar
HOCKEY
Default Re: Corsa Indy or Tourning (C5North)
Does the X pipe make a difference? And for the price.
[Modified by HOCKEY, 2:01 PM 2/13/2002]
Old Feb 13, 2002 | 09:07 PM
gbm's Avatar
gbm
Any of you guys get black instead of chrome and are you happy with it? I heard folks say that darker colored cars would look better with black, but now I'm not sure...
Old Feb 20, 2002 | 12:05 AM
HOCKEY's Avatar
HOCKEY
Default Re: Corsa Indy or Tourning (gbm)
I have Mag Red should I get the black or Chrome? What looks better.
Old Feb 20, 2002 | 01:09 PM
  #33
gbm's Avatar
gbm
I ended up buying the stainless or 'chrome' finish. - saw black and it's not as nice, I think
