Lots of Codes
Old Apr 24, 2009 | 12:36 PM
justin_heat05's Avatar
justin_heat05
Default Lots of Codes
B0333- Outside Air temp Sensor
B0367-Right Actuator Feedback Open
B0446-Right Actuator Out of Range
P1275-APP Sensor 1 Circuit
P1276- APP Sensor 1 Circuit Performance
P1545-A/C Clutch Relay Control Circuit
P0530-A/C Refrigerant Pressure Sensor Circuit
P0410
C1218-Pump Motor Circuit Shorted to Voltage or Motor Ground Open
C1288-Service Traction Control
B0502-RH DRL Relay Circuit
B0507-LH DRL Relay Circuit
B2482-Backup Lamp Relay Circuit
B2527-Horn Relay Circuit
B2587-Column Lock/Unlock Drive (A)
B2592-Column Lock/Unlock Drive (B)
U1096-
U1064
Are there any easy fixes to these? And which take a lot of work and money to fix? I'm new at these technical things....................Please explain....Help appreciated.......
Old Apr 24, 2009 | 12:37 PM
justin_heat05
Ive looked them up, just need help and instructions on fixing them.
