Check Valve for Washer Fluid?
Old Apr 25, 2009 | 01:28 AM
Choreo's Avatar
Choreo
Default Check Valve for Washer Fluid?
I have always noticed dried water droplets on my cowl first thing in th mornings. Now that I have a CF Hydrographic cowl that is clearcoated they really stand out. Is there a check valve or something that I can install in the washer lines to prevent this? I never use the washers, but they leak a few drops every trip for the past 8 years.
Old Apr 25, 2009 | 06:10 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Check the washer reservoir cap vent to make sure it's not plugged.
Old Apr 25, 2009 | 08:45 AM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
I think it's a common problem, try running a little less fluid in the tank.
Old Apr 25, 2009 | 11:00 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
As I was reading the post,,,,that the first thing that I though of!
I also agree with Quick Silver Z
You cant insert a check valve because, the if you put the check valve in the line to prevent drips, it would also prevents squirts.
There are pressure checks valves that you can install in the line. Those work by using a small poppet valve that opens as the pressure builds when you activate the washer system. Check NAPA. There OEM on different vehicles. C5s dont have them.
If you find one, and install it, make sure you install it close to the squirter as possible.
BC
Old Apr 25, 2009 | 06:15 PM
Choreo's Avatar
Choreo
Thanks for all the responses.
Old Apr 25, 2009 | 10:37 PM
sovetter's Avatar
sovetter
Navigator
Ford part no.F8CZ-17A614-AA less than $10.00.remove wiper arms.13mm bolts under the snap off caps.Wiggle and pull off wiper arms.Cut the wiper fluid tube under the blade assembly just before it spits into the 2 output nozzles and install the valve(1 each side)with the check ball pointing towards the pump,away from the nozzles and press fit the assemblyback under the wiper arm prior tore-install.Before removing wiper arms,turn ignitionto accessory,turn the wipers to slow intermittent and turn off the ignition when they are down at end of cycle but not parked on stops.Then mark windshield with masking tape for wiper arm position to indicate were to reinstall.No more leaks,hope this helps.
Old Apr 27, 2009 | 01:49 AM
Choreo's Avatar
Choreo
Interesting! I will check that out.
Old Apr 27, 2009 | 10:37 AM
87SAM's Avatar
87SAM
Actually GM does have a SB covering this:
Windshield Washer Nozzle Leaks on Windshield - appearance bleed check clearance damage fluid leak valve wet water window #PI00990 - (Apr 14, 2003)
Condition/Concern:
Windshield washer fluid drips onto windshield when accelerating or at highway speeds.
Recommendation/Instructions:
Install check valve PN 22102237 in the washer fluid hose before the tee to both nozzles with the arrow on the valve pointing in the direction of fluid flow. Verify operation of pump.
I suppose the cars acceleration does not provide enough force to open the check valve. Or, you could just not fill the reservoir past 2/3 full.
Old Apr 27, 2009 | 11:45 AM
Eric D's Avatar
Eric D
If he has a modified engine maybe he would need a sifter check valve to handle the added acceleration rate??
Old Apr 27, 2009 | 10:34 PM
Choreo's Avatar
Choreo
I have not noticed the problem under acceleration. Mine usually leaks when I pull up my relatively steep sloped driveway.
To Check Valve for Washer Fluid?
