Cooling help!
Old Apr 25, 2009 | 01:53 PM
1sickz51vette's Avatar
1sickz51vette
Default Cooling help!
Hey guys I replaced my radiator awhile ago, and just noticed that when I let the car sit running it will get up to 232 degrees and the fan's wont kick on unless I turn on the AC. I can do the "Ranger mod" and connect a wire to jump the relay circuit and they turn on fine, what could be the problem? Also I rarely use the heat in florida, but noticed the other night that sometimes it doesn't blow any hot air. Thanks for the help guys!
Old Apr 25, 2009 | 02:45 PM
clif's Avatar
clif
St. Jude Donor '09-'10
I agree. after running it, let it cool and recheck the level
Old Apr 25, 2009 | 04:03 PM
1sickz51vette
I think I'm just going to change the antifreeze again pretty soon. What would cause the fans to not kick on though?
Old Apr 25, 2009 | 05:51 PM
byronhunter's Avatar
byronhunter
You need this?
Check Fuse # 49
Old Apr 25, 2009 | 06:28 PM
1sickz51vette
Thanks for the diagram, I havent checked any fuses yet because the fans work when I do this mod to the relay...
http://rangeracceleration.com/C5_Fan_Trick.html
Old Apr 26, 2009 | 07:39 AM
Ranger's Avatar
Ranger
It's normal for the fans on a stock PCM to not come on until the coolant temp is 225 (or so) low-speed and 235 (or so) high-speed. No harm in that. That's the way it's designed.
It's only when you are concerned about max acceleration, such as at the drag strip, where you want the coolant temp to remain at or below 195. That's why I set out the "fan trick."
But for street driving, the stock system works fine and there's no harm at all for the temp to rise to 230 or so in traffic. It's normal.
Ranger
Old Apr 26, 2009 | 02:34 PM
fnsblum's Avatar
fnsblum
My C4 runs the same as my C5. While the mod shown will work, a switch installed in the circuit would be a lot handier. I am from the old school and like to see a constant temp around 200. I installed a switch in my C4. It was nice to have in stop and go traffic. Later! Frank
Old Apr 26, 2009 | 03:02 PM
1sickz51vette
Thanks for the feedback ranger, your fan trick works well!
My fans don't kick on whatsoever, and when the temps get up to like 235 you can smell the antifreeze for some reason.
Old Apr 27, 2009 | 08:29 PM
1sickz51vette
I'm not sure i completely understand the diagram, how can I check to know which relay is bad? If I replace all three and it still doesn't work, what could it be? The fans come on with the AC, or the fan trick otherwise nothing...
Old Apr 27, 2009 | 09:11 PM
byronhunter
Hey sickvett, when you turn the ac on, are you sure both fans are on, or just one? At no time should only one fan run by itself, always none, two at low speed, or two at high speed.
Old Apr 28, 2009 | 02:12 AM
1sickz51vette
both fans come on at once which I don't understand... I never had this problem until I replaced the radiator. Even without cooling fans though, it doesn't run over 232 if i let it sit.
To Cooling help!
