Loud fuel pump noise
Old Apr 25, 2009 | 07:06 PM
Kerls07's Avatar
Kerls07
Default Loud fuel pump noise
Does anyones fuel pump make a loud whining behind their head on drivers side?
Is that normal?
kerley
Old Apr 25, 2009 | 07:39 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
No noticeable noise from mine. Do you hear it all the time or only while you are moving?
Old Apr 25, 2009 | 07:49 PM
Kerls07's Avatar
Kerls07
It seems to be when car is first warming up and while I first start driving.
The car has had 3 owners before me and it maybe aftermarket but it is very loud in behind my head at first.
I can still hear it after it is warmed up.
kerley
Old Apr 25, 2009 | 07:58 PM
Eric D's Avatar
Eric D
kerley
Kerley,
Looking at your profile do you have a C6??? Might want to ask in the C6 section rather then the C5 area.
Old Apr 25, 2009 | 08:18 PM
TEXHAWK0's Avatar
TEXHAWK0
I think the answer to your question is that no fuel pump should be so loud that you notice it everytime you get in the car.
It should be more like a low hum than a loud whine.
Old Apr 25, 2009 | 08:27 PM
Blow Torch's Avatar
Blow Torch
Mine starting making a loud hum/hissing noise right before it went out. The noise is usually a sign of the pump working too hard. If you haven't already, try changing out the fuel filter first and see if that helps.
After that, put a fuel pressure gauge on it and do some test at idle, part throttle and WOT
Old Apr 25, 2009 | 09:06 PM
Kerls07's Avatar
Kerls07
I have a c5 I just bought and a c6
Old Apr 25, 2009 | 09:07 PM
Kerls07's Avatar
Kerls07
Where is fuel filter located?
Old Apr 25, 2009 | 10:24 PM
TEXHAWK0's Avatar
TEXHAWK0
Depends on what year your car is.
If you have a late 2003 or 2004 model, the fuel pump is in the left tank and non-serviceable.
Early and pre-2003, it is on the left frame rail behind the wheel.
Old Apr 25, 2009 | 11:19 PM
Smooth9883's Avatar
Smooth9883
I know the exact sound you are talking about. Mine isn't noticeable all the time but I do notice it often. I really notice it when I'm driving really hard through the mountains. I remember going up loveland pass last summer and hearing it sound like a turbo. It is somewhat bothersome but everything I have read said that it is fairly normal.
I'm not an expert though.
Old Apr 26, 2009 | 04:30 PM
Kerls07's Avatar
Kerls07
That would explain alot if it is behind drivers rear tire.
Thats why it is so loud
kerley
Old Apr 26, 2009 | 05:08 PM
lucky131969's Avatar
lucky131969
kerley
While "loud" is somewhat subjective, it is a common issue...with stock and aftermarket.
To Loud fuel pump noise
