Electrical Problems
Old Apr 26, 2009 | 05:25 PM
2A372C's Avatar
2A372C
Default Electrical Problems
1. C1226 Excessive Wheel Speed Variation this happens when you hit rough pavement, bump, or rough seam in the road.
2. Windshield Wipers don't want to work until you smack your fist on the steering wheel and then they only want to work on momentary and high.
3. Hazard Lights don't work..but blinker, day time running lamps, ect. work.
4. EVAP system not ready....no codes.
5. HVAC actuator fails....blows out all the vents.
Do all of these have a common denominator somewhere? Is this gods way of trying to take the joy out of my car?
Old Apr 26, 2009 | 05:37 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Ignition switch?
Old Apr 26, 2009 | 05:48 PM
2A372C's Avatar
2A372C
Yeah your right....hmmmm... I had some security fails as well.
Also the do do's that had the car before wired the radio in at the switch.
Where all the white women at?
Old Apr 28, 2009 | 04:38 AM
2A372C's Avatar
2A372C
Anyone else have any ideas other than the ignition switch?
Old Apr 28, 2009 | 05:32 AM
Eric D's Avatar
Eric D
For the types of problems you are having do a search on forum member Bill Curlee. Bill has a number of great write ups that cover issues like yours. Here is one of his write up. http://forums.corvetteforum.com/c5-t...tml?forum_id=1
Old Apr 28, 2009 | 09:04 AM
2A372C's Avatar
2A372C
Thanks I have read BC's post by the number and have been able to fix a lot of things on the car.
I do have an update: my car doesn't kick the 1226 code when its wet outside?
Old Apr 28, 2009 | 09:13 AM
Irish Whiskey's Avatar
Irish Whiskey
Got the 1226 or 1227 -can't remember which, when backing the car slowly and turning the wheels hard at the same time. The tire was pinching the sensor wire that runs from the wheel hub against the lower control arm and eroded some of the plastic casing that exposed the wires and shorted the system giving the code - the closest thing the computer could figure what was happening. I bet the code is related to something physical going on with the sensor cable out to the wheel. Fiddle with it or change it with the sensor cable on the other side and see if the problem "travels" with the wire.
One last thing ---electrical systems on the C5 will drive you nuts. I actually know several codes by heart!!
Old Apr 28, 2009 | 09:21 AM
poolboy's Avatar
poolboy
1. C1226 Excessive Wheel Speed Variation this happens when you hit rough pavement, bump, or rough seam in the road. - I would check to make sure the connectors to each wheel speed sensor are clean and tight. They are easy to find - they are the only electrical connections to each wheel
2. Windshield Wipers don't want to work until you smack your fist on the steering wheel and then they only want to work on momentary and high. May need a new switch
3. Hazard Lights don't work..but blinker, day time running lamps, ect. work. - May need to either bypass the hazzard switch or replace it
5. HVAC actuator fails....blows out all the vents. - There is a proceedure to reindex the actuators - are you getting codes for this? If you od need reindex here's a writeup - http://vette.tnreeds.com/actuator/actuator.htm
Do all of these have a common denominator somewhere? Is this gods way of trying to take the joy out of my car? Not that I can see - I think it is just possessed
Old Apr 29, 2009 | 03:28 AM
2A372C's Avatar
2A372C
Thanks I plan to tackle the reindex soon.
Old May 1, 2009 | 09:07 AM
2A372C's Avatar
2A372C
any other ideas?
Old May 1, 2009 | 09:28 AM
ptiller's Avatar
ptiller
Check Battery and Alternator. If Voltage is low, strange things can happen. Most electronics has a voltage regulator to keep them working at need voltage even when supply voltage dips, but Motors and other " power items" can be impacted. Long shot, but easy check.
Old May 4, 2009 | 03:16 PM
2A372C's Avatar
2A372C
Thanks I will check that as well.
Old May 7, 2009 | 02:34 AM
2A372C's Avatar
2A372C
OK I have a new battery but the problems still come and go the hazard lights still don't work as well as EVAP and HVAC problems are still present
To Electrical Problems
