Making noise
Old Apr 29, 2009 | 02:51 PM
ccw@thermousa.com's Avatar
ccw@thermousa.com
Default Making noise
I have a 1999 C-5 that whenever I go to back up and turn very sharply it makes a noise like the tire rubbing. I have pulled all 4 tires off and can not find any evidence of rubbing. I can't find anything wrong. anyone have any suggestions?
Old Apr 29, 2009 | 03:10 PM
JAY KOCH's Avatar
JAY KOCH
Check the front brake cooling ducts. You won't have to pull the wheels, just turn wheels full left and check the left duct, then full right to see if tire is rubbing on the right duct.
Good luck
Old Apr 29, 2009 | 03:16 PM
1sickz51vette's Avatar
1sickz51vette
mine does the same, still no answers.... it sounds like a weird scraping noise, but not plastic?
Old Apr 29, 2009 | 03:17 PM
ccw@thermousa.com
Thanks for the info. I checked these and they looked good. The noise sounds like it is coming from the rear, sounds like when driving a 4-wheel drive on pavement and you turn hard. I dont know it is driving me nuts!
Old Apr 29, 2009 | 04:58 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
The steering geometry isn't setup for sharp turns (on or near the turning stops) on Corvettes. The tire to floor contact will bind sliding the tires making the noise. If you try the same maneuver on a wet surface it shouldn't do it, if it does it might be something else.
Old Apr 29, 2009 | 08:41 PM
johnbadami's Avatar
johnbadami
Try changing the differential fluid and remember to add the slip additive.
To Making noise
