Check Engine Light Returns
Old Feb 3, 2002 | 09:21 AM
tpmy2k's Avatar
tpmy2k
3rd Gear
Default Check Engine Light Returns
I've read this is not an uncommon problem. Check engine light went on with gas tank at about 1/8 full. Filling tank and checking gas cap did nothing. Went to dealer with tank 7/8 full. They did a pressure test and couldn't find anything wrong but they did stop the light. Now light has come back on and lo and behold the tank is about 1/8 full (same tank of gas). Coincidence? Any experience with this? How can I get rid of the light without it coming back on every time I start the car. Searched codes and reset but it comes back every time I start the car even with tank full. This is totally annoying. Thanks!
Old Feb 3, 2002 | 01:18 PM
RadarBlue's Avatar
RadarBlue
Default Re: Check Engine Light Returns (tpmy2k)
Before reseting the codes the next time, write them down and post them here....
Without the codes, there's not much anyone can do :confused:
Old Feb 3, 2002 | 01:54 PM
Superj's Avatar
Superj
I had the same problem for about a month. I took it to the dealer 4 times and they couldn't fix it. They tried to tell me it ws caused by the Vortec intake. :bs I pulled the codes and had a grand total of 39 error codes. I took it to Frank Parra in Dallas. They kept it 5 days but they were able to fix it. The wiring harness along with some other components were damaged from battery acid. (Got a new battery too). Pull the codes and cross reference them in the tech section. Good luck.
Old Feb 4, 2002 | 09:07 AM
tpmy2k's Avatar
tpmy2k
3rd Gear
Thanks. I'll pull the codes and repost.
To Check Engine Light Returns
