Airconditioning Question
Old Apr 30, 2009 | 08:34 PM
paladin85's Avatar
paladin85
Default Airconditioning Question
My AC does not blow cold anymore. I can hear the compressor kick on. I thought if the AC was low on freon the compressor would not kick on. Could I have a problem with a vent door in the dash not opening or could it be low on freon.
Old Apr 30, 2009 | 11:18 PM
onetime21's Avatar
onetime21
5th Gear
Mine was doing the same. I done research and found out all I needed was one can of freon and its very cold now.
Old Apr 30, 2009 | 11:48 PM
jrose7004's Avatar
jrose7004
I imagine you need freon.
Old Apr 30, 2009 | 11:51 PM
Secret237's Avatar
Secret237
If the compressor kicks on then it still has pressure, so it's probably just low on freon.
You can get a can or 2 of freon from your local NAPA store with a hose to fill your system, it's actually pretty easy.
I like to us a little Oil charge myself everynow and then too, wouldn't want to burn up your compressor cause of not enough oil (ask me how I know)
Old May 1, 2009 | 09:38 AM
jedblanks's Avatar
jedblanks
The key here is whether
a) it's not blowing (meaning it's not coming out of the vents like you expect)
or
b) it's not cold
IMO the answers above are for situation "b". I'll add for that situation that the A/C is a closed system. So if you need freon, add it and that fixes it, then you likely have a leak somewhere and the problem will eventually return.
For situation "a"
If the vents aren't working, then it can be electrical (for auto ac) and will throw a code in the DIC, or it can be the MAP sensor Vacuum line at the back of the intake.
To Airconditioning Question
