1. Most of us defer to the experience and proven results from vendors that test and build replacement components, be it coil-overs or transverse leafs..
2. You’ve admitted that this application is not for a C5; judging by your corner weight values, it looks like you've got a front-end bias, something the C5 platform doesn’t have (almost perfect 50-50 front to rear distribution), which kind of makes any "C5 or C6" specific calibrations useless to you.
Good luck with your project.
well i obviously wasnt looking for C5 or C6 specific values. I was looking more for someone with some experience with vehicle weight vs. spring rate info. Or a formula i can use to determine the ideal rates for My vehicle. I asked this question here, because im using vette parts, and there seem to be alot of folks here who have some knowledge of how to get the most out of these suspension parts.
Not trying to give you are hard time, but your question can't be answered without more information. Things like, what the vehicle will be used for, track, 4 wheeling, drag. What type of tires, and much much more. Photos would help too.
Originally Posted by IMD
here are my current corner weights, if it helps. this will be for a daily driven vehicle, but i enjoy a firm ride, and the occasional track day.
LF-1340 RF-1201
LR-809 RR-822
(its not a vette, but has full C5 suspension, both ends)
im not sure how pictures will help determine my spring rate
as far as tires go, im going to be using 20" forged wheels that should weigh around 25 lbs ea. and front tires will be 275/45-20, with rears being 29x18x20.
