ls1 push rod lenth ?
Old May 6, 2009 | 10:40 AM
a/c man's Avatar
a/c man
Default ls1 push rod lenth ?
does anyone know the stock length of the factory push rods?and is ls1 and ls2 the same? also if you use a comp cam 54-444-11 will that change the push rod length? my heads have not been milled!stock gm lifters too! thanks scott
Old May 6, 2009 | 12:26 PM
vettenuts's Avatar
vettenuts
See below.
When I measured, I came up with 7.385" Gauge Length
I don't know
Base circle change will likely require a pushrod length change, best to buy an adjustable pushrod and measure. Buy pushrods last.
Old May 6, 2009 | 12:42 PM
a/c man's Avatar
a/c man
anyone else know more?please thank you vettenuts
Old May 6, 2009 | 01:05 PM
RKGarner's Avatar
RKGarner
I have the same Comp Cam 54-444-11 installed
Used the factory push rods
RKG
Old May 6, 2009 | 03:18 PM
a/c man's Avatar
a/c man
RKG
thanks what does your car idle at rpms?
Old May 7, 2009 | 08:21 AM
RKGarner's Avatar
RKGarner
On my way down to TX Vette Saturday to work out some cold start idling issues in the tuning. After the motor reaches 120+ it idles great, for a medium lift cam around 875 rpm. Just right, imo
Old May 13, 2009 | 11:16 AM
East Tx Muscle Cars's Avatar
0East Tx Muscle Cars
Former Vendor
with the comp cam you need some 7.4's in her because of the base circle being smaller...
To ls1 push rod lenth ?
